Images not downloading in Site Import
Thread begun 9/29/2012 7:01 pm by kg_nsa395746 | Last modified 10/04/2012 11:12 am by Jason Byrnes | 3815 views | 5 replies |
kg_nsa395746
I'm using Site Import in DW6. The download status shows images being downloaded but when I open a file in DW, I do not see any images. I was under the impression from the plugin description and video that the images would be imported. The CSS files aren't being imported either. Please advise. Thanks.
make sure that the import path you specify in the Import settings is to a site that you have defined in dreamweaver.
if you continue to have a problem, post back with details on what WebAssist extensions including version numbers you have installed, and a URL for the site you are trying to import.
kg_nsa395746
I received a call today from Ray in Sales and I walked through the Site Import steps while he was on the phone and now it's working. But if I run only Site Report, the status hangs up and doesn't finish. Any ideas?
what is the site you are importing?
What version of site import?
What is your OS?
What version of Dreamweaver?
kg_nsa395746
what is the site you are importing? www.plainviewsurgical.com
What version of site import? Bundled with Design Extender 1.1.1
What is your OS? Windows 7 Home Edition
What version of Dreamweaver? CS6 Cloud version
