Goolge pro maps is not showing up?
Thread begun 10/15/2012 8:15 am by Noa2086 | Last modified 10/17/2012 1:19 pm by Jason Byrnes | 5839 views | 13 replies |
Noa2086
Hi jason,
my google pro map is not showing up.
what could be the problem? i have an api key.
i would like to set up 4 addresses:
1. address: address 1 (address of the company)
2. address: starting address (user input)
3. address: destination (user input)
4. address: address 1 (back to the company)
insert the record in recordset "Route" and get it from there.
how can i extract the time to calculate the price per hour?
why is my session "ServiceID" not working?
if(isset($_POST["Route_submit"])) {
header("Location: index.php?ID=".((isset($_SESSION['ServiceID']))?$_SESSION['ServiceID']:"")."&Route=".((isset($_SESSION['RouteID']))?$_SESSION['RouteID']:"")."&tab=2#TabbedPanels");
thx for your help!
I dont see a map applied to this page you have linked to, there is no map added to this page.
I dont follow, extract the time from what?
I dont have enough info to tell why the session is not working, i would need a copy of the page to inspect the code.
Noa2086
hi jason,
thx for your quick reply. here is the zip.
google maps directions has a time from point a to b. for example 6 hours and 30 minutes.
how can i work with this (i think) variable?
that is not supported in promaps, you need to hand code that to return the travel time:
using-google-maps-api-to-get-travel-time-data
Noa2086
This post has been deleted.
there is no need to pass the session to the URL. Just reference the session variable directly rather then trying to pass it to the URL to use the URL variable, thats a lot of extra work that is not needed.
to show multiple addresses on the map, click the plus button to add the first address, click the plus button again to add the second address and so on, see the attached screen shot.
Noa2086
to refer to a session variable use code similar to this::
<?php echo($_SESSION['sessionName']); ?>
you seam to be hand coding the map, we con not offer support for hand coding the map.
Noa2086
ok thx. just for the record i summarize:
1) with promaps it is not possible to have the direction function with more than two points. thx for the input with stackoverflow.
2) i haven't understand the session answer yet.
i start the session with this code:
if("" == "") {
$_SESSION["ServiceID"] = "".$_GET['ID'] ."";
i put the id with a session in the url with this code:
header("Location: index.php?ID=".((isset($_SESSION['ServiceID']))?$_SESSION['ServiceID']:"")."&Route=".((isset($_SESSION['RouteID']))?$_SESSION['RouteID']:"")."&tab=2");
where should i place your code?
1) Yes it is, you have to select which point is the Destination though.
2) passing the session through the URL Variable like this does not make sense.
the whole point of using session variables is that once they are set they are available to all of the pages in your site. you don't need to pass the session using the URL.
instead you can reference the session on the index.php page just be using the code i gave.
one point:
this code:
if("" == "") {
will set the session on page load, regardless of whether the ID url variable has a value or not.
you may want to change the trigger for the set session value code to use the ID url variable.
