Universal Email File Upload Issues
Thread begun 10/17/2012 4:01 pm by sandy259886 | Last modified 10/19/2012 8:32 am by Jason Byrnes | 2230 views | 3 replies |
sandy259886
I have Dreamweaver CS6 and I am trying to create a file upload page. I haven't used this extension since I upgraded to CS6, so I'm not sure if it is compatible. Anyway, when I try to add the file download behavior, I click on the lightning bolt to add a dynamic file and the new window flashes and keeps flashing after I try to select my dynamic selection. Then, I have to Force Quit Dreamweaver to close the webassist window. I have cleared out the cache, removed and re-installed the latest version of Universal Email 4.01 and it still won't work.
Universal Email 4 is not compatible with DW CS6, you will need to use a previous DW version with UE4.
If you wish to continue using Dreamweaver CS6, you will need to upgrade to Data Bridge. data Bridge is a consolidation of the following extensions into one installer:
--CSS Button Styler
--CSS Form Builder
--DataAssist
--Digital File Pro
--Dynamic Connections
--Dynamic Dropdowns
--Dynamic Web Charts
--Form Toolkit
--HTML Editor
--Image Resizer
--SecurityAssist
--Universal Email
--Validation Tooltips for Spry
--Framework Builder
sandy259886
Not good
Does Data Assist work with CS6?
No, data Assist 2 is not compatible withDW CS6, the Data Bridge upgrade includes the Newer Data Assist 3 though.
if you wish to continue using Data Assist 2, you will need to use a previous version of Dreamweaver.
