Image not dislaying error in SQL
Thread begun 10/22/2012 2:16 pm by jo271221 | Last modified 11/19/2012 1:59 pm by Jason Byrnes | 4771 views | 8 replies |
jo271221
I created member directory and member pages using databassist. On the post detail page I would like to display the customers logo from the directory table if the post does not include an image. Here is my attempt and attached as well. _p_detailNEW.php?postid=9151 Here is the working page. p-detail.php?postid=9151 This postid 9151 does NOT have an image. postid 2822 DOES have a 1st image. postid 9151 should display the logo from their directory listing. Directory-Detail.php?id=909 I can see I have an error at line 60 but I don't know what it is.
the error is happening because of the run time value you entered for the Paramid parameter of the directory recordset.
the run time value you used:
$_[GET]"id"
should be:
$_GET["id"]
jo271221
Logo Image still not displaying
Thank You, the error is resolved but the customers logo is not displaying. I double checked and it is in the database and displays on their directory listing page. Directory-Detail.php?id=909 but it is still not displaying on the post detail page. _p_detailNEW.php?postid=9151. I put bound just the filename at the top of the page after the business name just to be sure it was not an image issue or show if issue and the file name does not appear either.
the link the _p_detailNEW.php page is not passing a URL variable name d ID, it is passing postid.
try using $_GET["postid"] as the run time value in your recordset.
jo271221
Resolved!
That did it. Thank You!!!
jo271221
not working
I am not sure how I broke this, but I just checked this page and the image is NOT displaying.
Here is the current code<?php
$Parampostid_WADAtbl_post = "-1";
if (isset($_GET['postid'])) {
$Parampostid_WADAtbl_post = $_GET['postid'];
$ParamSessionpostid_WADAtbl_post = "-1";
if (isset($_SESSION['WADA_Insert_tbl_posts'])) {
$ParamSessionpostid_WADAtbl_post = $_SESSION['WADA_Insert_tbl_posts'];
$Parampostid2_WADAtbl_post = "-1";
$Parampostid2_WADAtbl_post = $_GET['postid'];
mysql_select_db($database_community, $community);
$query_WADAtbl_post = sprintf("SELECT tbl_posts.*, listadforms.formfile FROM tbl_posts left join listadforms on tbl_posts.ad_category = listadforms.formid WHERE postid = %s OR ( -1= %s AND postid= %s)", GetSQLValueString($Parampostid_WADAtbl_post, "int"),GetSQLValueString($Parampostid2_WADAtbl_post, "int"),GetSQLValueString($ParamSessionpostid_WADAtbl_post, "int"));
$WADAtbl_post = mysql_query($query_WADAtbl_post, $community) or die(mysql_error());
$row_WADAtbl_post = mysql_fetch_assoc($WADAtbl_post);
$totalRows_WADAtbl_post = mysql_num_rows($WADAtbl_post);
$Paramid_directory = "-1";
if (isset($_GET['id'])) {
$Paramid_directory = $_GET['postid'];
$query_directory = sprintf("SELECT logo_img FROM tbl_directorylistings WHERE %s=id", GetSQLValueString($Paramid_directory, "int"));
$directory = mysql_query($query_directory, $community) or die(mysql_error());
$row_directory = mysql_fetch_assoc($directory);
$totalRows_directory = mysql_num_rows($directory);
Page - _p_detailNEW.php?postid=9187
This user does have a logo - Directory-Detail.php?id=4334 top left image is the logo
I'll need the full page please in a zip archive to see the code in context.
jo271221
Image and style sheet from member's profile
I have attached post detail and results page. In addition to getting the logo_img I also want to get the fldstylesheet to be bound on these pages. logo_img and fldstylesheet are in the table tbl_directorylistings, the pages are getting the rest of the information from tbl_post table.
your recordset is not querying the tbl_directorylistings table. it is only returning data from the tbl_posts and listadforms tables.
if you need to return data from the tbl_directorylistings table also, you will need to add that table to the recordset.
