When I view source of your page, I see the following code before the doctype tag:
<style type="text/css">
Label {text-transform:uppercase;background:#f9f1e1;padding:0px;}
.inputValue {width:95%;}
.inputText {width:95%; height:50px;}
.inputButton {}
.emailFormError {margin:0px; color:#FF0000}
.style1 {color: #848484}
</style>
function WAtrimIt(theString,leaveLeft,leaveRight) {
if (!leaveLeft) {
while (theString.charAt(0) == " ")
theString = theString.substring(1);
if (!leaveRight) {
while (theString.charAt(theString.length-1) == " ")
theString = theString.substring(0,theString.length-1);
return theString;
function WAFV_GetValueFromInputType(formElement,inputType,trimWhite) {
var value="";
if (inputType == "select") {
if (formElement.selectedIndex != -1 && formElement.options[formElement.selectedIndex].value && formElement.options[formElement.selectedIndex].value != "") {
value = formElement.options[formElement.selectedIndex].value;
else if (inputType == "checkbox") {
if (formElement.length) {
for (var x=0; x<formElement.length ; x++) {
if (formElement[x].checked && formElement[x].value!="") {
value = formElement[x].value;
break;
else if (formElement.checked)
value = formElement.value;
else if (inputType == "radio") {
for (var x=0; x<formElement.length; x++) {
break;
else if (inputType == "radiogroup") {
break;
else if (inputType == "iRite") {
var theEditor = FCKeditorAPI.GetInstance(formElement.name) ;
value = theEditor.GetXHTML(true);
else {
var value = formElement.value;
value=value.replace(/<p>(\&\#160\;)*<\/p>/,"");
if (trimWhite) {
value = WAtrimIt(value);
return value;
function WAAddError(formElement,errorMsg,focusIt,stopIt) {
if (document.WAFV_Error) {
document.WAFV_Error += "\n" + errorMsg;
else {
document.WAFV_Error = errorMsg;
if (!document.WAFV_InvalidArray) {
document.WAFV_InvalidArray = new Array();
document.WAFV_InvalidArray[document.WAFV_InvalidArray.length] = formElement;
if (focusIt && !document.WAFV_Focus) {
document.WAFV_Focus = focusIt;
if (stopIt == 1) {
document.WAFV_Stop = true;
else if (stopIt == 2) {
formElement.WAFV_Continue = true;
else if (stopIt == 3) {
formElement.WAFV_Stop = true;
formElement.WAFV_Continue = false;
function WAValidateRQ(formElement,errorMsg,focusIt,stopIt,trimWhite,inputType) {
var isValid = true;
if (!document.WAFV_Stop && !formElement.WAFV_Stop) {
var value=WAFV_GetValueFromInputType(formElement,inputType,trimWhite);
if (value == "") {
isValid = false;
if (!isValid) {
WAAddError(formElement,errorMsg,focusIt,stopIt);
function WAValidateEM(formElement,value,errorMsg,focusIt,stopIt,required) {
var isValid = true;
if ((!document.WAFV_Stop && !formElement.WAFV_Stop) && !(!required && value=="")) {
value = value.toLowerCase();
var knownDomsPat = /^(com|net|org|edu|int|mil|gov|arpa|biz|aero|name|coop|info|pro|museum)$/i;
var emailPat = /^(.+)@(.+)$/i;
var accepted = "\[^\\s\\(\\)><@,;:\\\\\\\"\\.\\[\\]\]+";
var quotedUser = "(\"[^\"]*\")";
var ipDomainPat = /^\[(\d{1,3})\.(\d{1,3})\.(\d{1,3})\.(\d{1,3})\]$/i;
var section = "(" + accepted + "|" + quotedUser + ")";
var userPat = new RegExp("^" + section + "(\\." + section + ")*$");
var domainPat = new RegExp("^" + accepted + "(\\." + accepted +")*$");
var theMatch = value.match(emailPat);
var acceptedPat = new RegExp("^" + accepted + "$");
var userName = "";
var domainName = "";
if (theMatch==null) {
isValid = false;
else {
userName = theMatch[1];
domainName = theMatch[2];
var domArr = domainName.split(".");
var IPArray = domainName.match(ipDomainPat);
for (x=0; x < userName.length; x++) {
if ((userName.charCodeAt(x) > 127 && userName.charCodeAt(x) < 192) || userName.charCodeAt(x) > 255) {
isValid = false;
for (x=0; x < domainName.length; x++) {
if ((domainName.charCodeAt(x) > 127 && domainName.charCodeAt(x) < 192) || domainName.charCodeAt(x) > 255) {
isValid = false;
if (userName.match(userPat) == null) {
isValid = false;
if (IPArray != null) {
for (var x=1; x<=4; x++) {
if (IPArray[x] > 255) {
isValid = false;
for (x=0; x < domArr.length; x++) {
if (domArr[x].search(acceptedPat) == -1 || domArr[x].length == 0 || (domArr[x].length < 2 && x >= domArr.length-2 && x > 0)) {
isValid = false;
if (domArr[domArr.length-1].length !=2 && domArr[domArr.length-1].search(knownDomsPat) == -1) {
isValid = false;
if (domArr.length < 2) {
isValid = false;
if (!isValid) {
function WAAlertErrors(errorHead,errorFoot,setFocus,submitForm) {
if (!document.WAFV_StopAlert) {
document.WAFV_StopAlert = true;
if (document.WAFV_InvalidArray) {
var errorMsg = document.WAFV_Error;
if (errorHead!="")
errorMsg = errorHead + "\n" + errorMsg;
if (errorFoot!="")
errorMsg += "\n" + errorFoot;
document.MM_returnValue = false;
if (document.WAFV_Error!="")
alert(errorMsg.replace(/"/g,'"'));
else if (submitForm)
submitForm.submit();
if (setFocus && document.WAFV_Focus) {
if (document.getElementById(document.WAFV_Focus.name+"___Config") && document.WAFV_Focus.type.toLowerCase() == "hidden") {
var theEditor = FCKeditorAPI.GetInstance(document.WAFV_Focus.name);
theEditor.EditorWindow.focus();
setTimeout("setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
document.tempFocus = document.WAFV_Focus;
setTimeout("document.tempFocus.focus();setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
for (var x=0; x<document.WAFV_InvalidArray.length; x++) {
document.WAFV_InvalidArray[x].WAFV_Stop = false;
else {
if (submitForm) {
document.MM_returnValue = true;
document.WAFV_Focus = false;
document.WAFV_Error = false;
document.WAFV_InvalidArray = false;
</script>
it should be moved so that it is after the <head> tag instead.
