Getting a warning re:WAVT_Scripts_PHP.php
Thread begun 8/07/2009 2:52 pm by iggymak198560 | Last modified 8/19/2009 2:14 pm by Eric Mittman | 7254 views | 9 replies |
iggymak198560
I'm having difficulty getting it to send mail and then go to the thank you page. I am a PHP neophyte so I'm not sure how it all works, having only a marginal understanding. I tried searching through here but didn't see anything...
It's on a Linux server at Datapipe.
For this site - contact.php, when I hit submit I get this message...
Warning: Cannot modify header information - headers already sent by (output started at /home/sites/www.skylaire.com/web/ContactForm_GMC/contact.php:1) in /home/sites/www.skylaire.com/web/ContactForm_GMC/WA_ValidationToolkit/WAVT_Scripts_PHP.php on line 68
Here are the lines around 68:
61: if (isset($_SERVER['QUERY_STRING']) && ($_SERVER['QUERY_STRING'] != '')) {
62: if (strpos($thePostURL,"?") !== false) {
63: $thePostURL.= "&" . ($_SERVER['QUERY_STRING']);
64: } else {
65: $thePostURL.= "?" . ($_SERVER['QUERY_STRING']);
66: }
67: }
68: header("Location: ". $thePostURL);
69: exit;
70: }
I tried doing this - changing a line on the contact page as noted in other posts here to if ($_SERVER["REQUEST_METHOD"] == "POST") {, but it didn't help. I have 5 other sites on the same server (I think it's the same, at least) and they all worked after changing that request method line so I'm kind of stymied. None of the others gave a warning, they all just refreshed the contact page.
A programmer said it might have a different IP #... but I'm not sure how that'd affect it.
I think I have to take something out somewhere to let it work, as somewhere it already tried to send it it seems... but I've no idea what or where!
Can someone have a look?
Thanks,
Iggy
When you get the headers already sent message like this it is usually because of some white space or other characters that occur outside of the php blocks. This can normally be corrected by examining the tags on the page near the error so that you find and remove any white space.
When you get the error like this at line one it can sometimes be due to a special character that is encoded and set as the first character of the page. In DW you can test for this by doing a save as for the page, in the dialog that appears make sure that you do not have the option for 'Include Unicode Signature (BOM)' checked. Having this option enabled can put this extra character at the beginning of your file and cause this error.
Please try these things and post back with what you discover.
iggymak198560
better, but...
Thanks, we are farther along!
I looked for white spaces, and believe I found one, which I got rid of, but the big one was that it had indeed been set to include the BOM, (also on the thankyou.php page).
When I saved it with that setting off, things changed...
Now, I no longer get that warning, but, it still doesn't send the mail or go to the thank you page.
We're getting there for sure... I did try both setting of the request method, just in case... no difference noted...
What do you think's up?
What page do you go to when you submit the form? You should be going to a thank you page of some type after the email has been sent. If you are not getting to the thank you page then this would indicate a problem elsewhere on the page when being processes.
iggymak198560
it just refreshes the contact page
...taking away the field contents as if you hadn't started yet, no thank you redirect.
So far I've tried both versions of the request line as shown in other posts, and with and without the email server named in Globals... Do you think you possibly could spot the strangeness? Do you need to see anything else?
contact.php
the top php code is the same as all the other sites I have there, I checked again for white spaces after the lines end.
It sounds like you are getting some type of server validation failure on the page. Take a look at the code toward the top of the page and look for this php code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
When you find this you should update it so it looks like this:
die("the validation errors are: " . $WAFV_Errors);
After you make this update upload and test the page, if you get the message about the validation errors please post back with the results. If you do not see any message let me know and I can open a ticket for you on this.
iggymak198560
okay, here's what I got...
Thanks, Eric,
I made that change and I got this message on an otherwise blank page:
the validation errors are: ,4,5
Hope that tells you what you need to know!
Iggy
Thanks for the info, this tells me that you have validations that are failing on the page. The validations that are failing on the page are the CAPTCHA and the security question. There should be some validation show if regions that will let you know that these values were not entered correctly.
Please try removing the debug code and testing again to determine if you are getting the validation errors to show on the page.
If you want to make it so the fields retain what was entered into them you will need to set their values like this:
Contact_Name:
<?php echo(ValidatedField("contact","Contact_Name")) ?>
Email_address:
<?php echo(ValidatedField("contact","Email_address")) ?>
Comments:
<?php echo(ValidatedField("contact","Comments")) ?>
The security code and question should not be defaulted to the previous values.
iggymak198560
Working!
It's now working. At first it wouldn't, though. After the last test I erased everything from local and server and started all over again, using all the precautions you mentioned. And at first that didn't work either so I did it all again, this time copying my code from the existing page onto the premade one, instead of the other way around, just in case, and that last time it worked perfectly. It must have been just the BOM code in concert with some hidden anomaly, perhaps caused by a fault in copying or pasting. Not 100% sure, but that's what I think. As I say, it now works as it should.
Thanks, Eric, be well :)
That is awesome to hear, I'm not sure if you will ever know specifically what the problem was but at least you have it working now. I have a feeling like yours that it may have been a combination of issues including the BOM.
