odd characters in HTMLEditor
Thread begun 3/21/2013 8:39 am by Christopher West | Last modified 3/21/2013 3:42 pm by Patrice | 2681 views | 5 replies |
Just a quicky...Using HTMLEditor
and I have noticed that on some pages I had odd characters being displayed...on inspecting the actual database I noticed that these characters were made up of code such as..
Im assumning its only happening when copy/pasting in text.. even removing formatting doesnt do anything and even deleting the odd character and replacing it sometimes doesnt help.
I just wondered why these characters would appear?
in my pages the doctype etc is:
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
<meta http-equiv="Content-Language" content="en-gb">
and in my database the tables are created as: InnoDB Latin1_Swedish_ci (the default)
should it be utf8_general_ci ??
Or am I missing something else?
Chris
Use the Dynamic Connections for creating the database connection, in Dynamic Connections, set the character set for the connection to UTF-8
Hi Jason couple of questions.
1. I have always used the standard database connection rather then the dynamic one...so what difference would that make to UTF8..Why wouldnt the previous connection be good enough?
2. Should I be setting all my database tables to use utf8_general_ci then? Is this optimised for the use of HTMLEditor?
I have done the connection you stated, i deleted the previous one and deleted the localhost files and recreated them...now im getting this †is quite a few areas of my content...would i now need to go through the whole content of the website to correct manually in the database?
and will this change reflect any future edits of the content?
Chris
1) The standard DW Connection doesn't allow you to set the character set used for the connection. This can cause UTF - 8 characters to become munged during transmission from the form to the database. the default connection character set is the iso-8859-1 character set.
doesn't matter what the database character set is if the connection is transmitting to and from the database using the iso-8859-1 character set.
2) It's not so much about optimized for HTML Editor, as it for the language characters you will be using.
changing the character set cant correct problems that already exist, but it should prevent them from being inserted in the future.
Thanks Jason, I have always used the standard database connection setup. so for future will use the webassist version and use utf8. I just want to try and keep to one standard since all the web projects I do are all UK based so I dont need to mess around with different character sets. just the one generic one for English speaking content.
Chris
PatriceWebAssist
Thanks for this post and solution. I ran into the same thing last week. I assumed it was the copy paste issue too.
This was my post link: showthread.php?t=30377
