Can't get file to upload
Thread begun 8/12/2009 4:24 pm by jeff_theiler382828 | Last modified 8/14/2009 9:47 am by Jason Byrnes | 5008 views | 7 replies |
jeff_theiler382828
Having trouble with file upload on DFP. It was working before, but isn't now. I made a bare-bones page to try and isolate error, but still can't figure it out. When I go to the folder where the file "should" be, there is no file there.
Any ideas?
Thanks.
Code is:
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "Image1/",
'FileName' => "pepper",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "pic load", "2", "[NewFileName]_[Increment]", "JPG:30", $WA_UploadResult1_Params);
<head>
</head>
<body>
<form id="form1" name="form1" enctype="multipart/form-data" method="post" action="">
<p>
<input type="file" name="pic load" id="pic load" />
</p>
<p>&nbsp;</p>
<p>
<input type="submit" name="submit" id="submit" value="Submit" />
</p>
</form>
</body>
</html>
one problem I can see is that the file field has a space in the name:
name="pic load"
Form elements cannot have spaces in the name, change that to:
name="pic_load"
then edit the Upload server behavior and reselect the file field.
jeff_theiler382828
I saw that too. I changed that as suggested but still no upload. The debugging info tells me no file uploaded as well. I'm perplexed.
jeff_theiler382828
Wait a minute, thanks the upload works! However, when I reassociated, I now get this error message:
Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 14592 bytes) in C:\xampp\htdocs\rent_monkey\WA_DigitalFilePro\HelperPHP.php on line 849
I'm trying to resize jpg's.
try changing the memory_limit setting in the php.ini file.
You may need to increase it to as much as 256M.
jeff_theiler382828
hmmm. spent a couple of hours trying to do this, using other web info. I tried to adjust the php.ini-dist file (all of this stuff is on an Apache internal sever I did with the standard set up to test the webpages before publishing them). I can't find just a php.ini file. It appears from the commentary I read, that it would just be a matter of opening with notepad and replacing the text in the memory_limit line, but it is really unclear to me where this file is?
The php.ini-dist adjustment didn't do anything.
Any ideas?
jeff_theiler382828
Resolved problem. If anyone is curious, need to go to localhost/xampp/[/url] and go to phpinfo() to find the right php.ini file. Adjust as stated above. Restart apache and double check that the change took place [also found in phpinfo() ]. Then the file uploads will work as they should.
Excellent, glad to hear it is sorted.
