The quotation marks surround a search phrase
Thread begun 4/15/2013 2:15 am by superpac250441 | Last modified 4/18/2013 6:22 am by superpac250441 | 2161 views | 5 replies |
superpac250441
Is there a way to build in quotation marks into a database search so that the user does not need to type quotation marks to surround a search phrase?
you can force the quotes through php code, for example if the search form uses the GET method, and the search field is named "keyword":
if(isset($_GET['keyword']) && $_GET['keyword'] != "") {
$_GET['keyword'] = "\"".$_GET['keyword']."\"";
superpac250441
Hi again Jason, if I use post, would this be correct?:
if(isset($_POST['Products']) && $_POST['Products'] != "") {
$_POST['Products'] = "\"".$_POST['Products']."\"";
If it is correct, where exactly do I place this code? At the top of the results page?
Many thanks
Yes, that would be correct for the POST method. Place the code at line 1 of the results page.
superpac250441
Excellent thanks Jason. It works a treat!!
