Compatibility with DW CS7
What are your plans for making your extensions compatible with DW CS7? (Server behaviors. database, etc., being removed. Spry no longer supported/included. Etc.)
After CS 7 is released, we will be updating Data Bridge and Design Extender to replace functionality that adobe are removing in terms of server behavior support.
We will be transitioning from the use of the Spry Framework to the use of jQuery to be inline with the change in CS 7.
Will these upgrades be backward compatible with CS6??
Yes, the upgrades will be backward compatible
Thanks Jason -- well deserved shout-out in the newsletter!!
This is awesome news and reassuring to know that WA are on the case
Updates will be released soon after the release of DW CS7. I can not give a more specific date
