Path to PEAR
Thread begun 5/25/2013 11:27 pm by teresa328019 | Last modified 5/29/2013 11:38 am by Jason Byrnes | 20528 views | 11 replies |
teresa328019
Path to PEAR
I've installed PEAR on my server and installed the Mail PHP extension. I am having trouble figuring out how to get the path to PEAR.
I followed this page for installing PEAR on my server, inmotion hosting.
http://www.inmotionhosting.com/support/website/cpanel/how-to-install-a-pear-module
Then I installed Mail.
http://www.inmotionhosting.com/support/website/how-to/install-pear-extensions
The problem is figuring out what my Path to Pear should be.
These are the errors I'm getting:
Warning: require_once(../../phpMail.php) [function.require-once]: failed to open stream: No such file or directory in /home/sisosm5/public_html/webassist/email/PEAR_Mail_using_SMTP_php.php on line 115
Fatal error: require_once() [function.require]: Failed opening required '../../phpMail.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/sisosm5/public_html/webassist/email/PEAR_Mail_using_SMTP_php.php on line 115
teresa328019
My php.ini in the server did not appear to be including the php folder where Net_SMTP as installed.
Inmotion added this to be included.
Changed
include_path = ".:/usr/lib/php:/usr/local/lib/php"
to
include_path = ".:/home/sisosm5/php:/usr/lib/php:/usr/local/lib/php"
I'm not getting any errors anymore but the page is taking a really REALLY long time to submit and I'm not getting the form sent to my email. It is going to the thankyou.php page.
add the following code to the thank you page, it will write the session contents and include details of whether the email is being passed to the SMTP Server:
<?php @session_start(); var_dump($_SESSION); ?>
teresa328019
see private message
The Connection to the ftp server is failing:
Sending To: supportedindependence@sisocare.com... 10001 - Failed to connect to secure46.inmotionhosting.com:465 [SMTP: Invalid response code received from server (code: -1, response: )] - Failure
it is giving a response code of -1.
you will need to contact the host to determine why connecting to the SMTP server is not working.
teresa328019
I've contacted inmotion hosting and they told me it was a coding issue. Not an issue with the server. The contact form located at http://sisocare.com/contact.php works fine. But the form at http://sisocare.com/applicationform2.php is having issues. I have no idea what the problem is or why one form would work and another won't.
well, the contact.php page is not using Pear Mail for SMTP, it is using the standard mail() function to send the emails. in the WA_Globals/WA_Globals.php file what is being used for the SMTP server?
Use the same setting in Universal Email and set the mail object to use mail instead of Pear Mail.
teresa328019
I tried that. These are the errors:
Notice: Undefined index: waue_applicationform_1_Error in /home/sisosm5/public_html/webassist/email/mail_php.php on line 298
Notice: Undefined index: waue_applicationform_1_Status in /home/sisosm5/public_html/applicationform2.php on line 170
Notice: Undefined index: waue_applicationform_1_Index in /home/sisosm5/public_html/applicationform2.php on line 171
Notice: Undefined index: waue_applicationform_1_From in /home/sisosm5/public_html/applicationform2.php on line 172
Notice: Undefined index: waue_applicationform_1_To in /home/sisosm5/public_html/applicationform2.php on line 173
Notice: Undefined index: waue_applicationform_1_Subject in /home/sisosm5/public_html/applicationform2.php on line 174
Notice: Undefined index: waue_applicationform_1_Body in /home/sisosm5/public_html/applicationform2.php on line 175
Notice: Undefined index: waue_applicationform_1_Header in /home/sisosm5/public_html/applicationform2.php on line 176
Notice: Undefined index: waue_applicationform_1_Log in /home/sisosm5/public_html/applicationform2.php on line 177
Warning: Cannot modify header information - headers already sent by (output started at /home/sisosm5/public_html/webassist/email/mail_php.php:298) in /home/sisosm5/public_html/applicationform2.php on line 180
Originally Said By: teresa328019
teresa328019
ok
