map not centering in pop up
Thread began 5/31/2013 8:55 am by Jamie | Last modified 6/13/2013 4:23 am by Jamie | 2467 views | 14 replies |
Jamie
Hey Jason
Just wondering what I might be doing wrong on this site : http://clients.motley.co.uk/young/
If you scroll to the bottom you'll see a map in the footer which, when clicked, opens a modal window with a wa google map in it. As you can see in the pop up, the map is not centering nor is the full map visible and I dont know how to correct this?
Many thanks
Jamie
change the code to open the map to:
<a href="#?w=620" rel="map" class="poplight" onClick="window.setTimeout('google.maps.event.trigger(map1,\'resize\');wagmp_map_1_obj.obj.setCenter(wagmp_map_1_obj.points[0])',30);"><img  src="images/main/map.jpg" width="160" height="160" alt="Google Map for Chris Young Opticians"></a>
Jamie
Thanks Jason. That's done the trick. I have also tried to stop the info from opening and commented out the line in the js as have done before but the info window still shows ...
in the isdefault code:
if (isDefault) {
//infowindow.open(map1,marker);
setTimeout("google.maps.event.trigger(wagmp_map_1_obj.markers[" + wagmp_map_1_obj.markers.length + "], 'click')",1000);
//map1.setCenter(point);
you have the line to force the click, which opens the info window, change that to:
if (isDefault) {
// setTimeout("google.maps.event.trigger(wagmp_map_1_obj.markers[" + wagmp_map_1_obj.markers.length + "], 'click')",1000);
Jamie
thanks Jason :)
have a great weekend
Jamie
Hey Jason
On this site I have been workign on mod_rewrites which are workign fine. The 'issue' is to do with the map at the bottom of each page.
On a standard page (eg http://www.cyoungopticians.co.uk/about.php the pop up map works fine and displays the map itself.
But the problem comes when on a dynamic page which has had mod_rewrite applied to it (eg http://www.cyoungopticians.co.uk/s6/spectacle_frames.php
Its obviously a path thing but for the life of me cant see what is stopping this one thing from working.
Many thanks
Jamie
try adding a base tag just after the opening <head> tag:
<base href="http://www.cyoungopticians.co.uk/" />
Jamie
Thank you
Jamie
I've added the tag to the pages with the tabbed panels, and it was all working fine... but now I have lost the map from the pop up on every page...
