WA Validated Entries
Thread begun 5/31/2013 1:00 pm by Cologne | Last modified 5/31/2013 7:04 pm by Jason Byrnes | 5149 views | 15 replies |
Cologne
I remember there was something like a parameter that could be added if there was no "WA Validated Entries".
Wasnt it possible to choose an alternative entry?
Like: If there is no WA Validated Entry -> use -> Recordset
Cheers,
Denis
see this thread:
http://www.webassist.com/forums/showthread.php?t=27290
Cologne
Hi Jason,
I red that threat, but I think I am sure that there was something like this from WA. Maybe in an earlier VTK version.
I remember it worked without using an URL parameter.
hmmmm...
no, it needs to use a URL parameter to know whether it should use the validated entries or recordset.
Cologne
strange, I got it in my mind.
I will give it a try.
Will this be save: update.php?valid=false
it seems I need an other validation, that $valid is only letters, or not?
?valid=false is just the URL Variable you add to the validation fail to tell the page whether to use the validated entries or recordset.
Cologne
http://localhero.de/test.php
When I enter wrong data it works.
But this happens: http://localhero.de/test.php?valid=false&valid=false
If you delete the @ and change the names
the failed redirect in the validation behacor does not include the valid=false url perameter.
when validation fails it returns to:
it should return to:
Cologne
Hi Jason,
now it seems to work, but doubles the valid
http://localhero.de/test.php?valid=false&valid=false&valid=false&valid=false
you most likely have the action of the form set to pass the URL variables that are passed in back out. Send a copy of the page.
