Error in server behaviour eCart object: the participants property..
Thread began 3/25/2009 4:38 am by info303815 | Last modified 3/31/2015 10:41 am by Jason Byrnes | 3699 views | 10 replies |
info303815
Every time I change something in Dreamweaver, I get an popup -error message telling me:
Error in server behavior eCart object: the participants property is not an array, or the elements in the array are not nodes in the document.
(Please see the attached image.)
Please submit an incident and include a copy of your page. Something is probably missing or written wrong causing the error.
laurafrd398148
Server Error eCart Object - Same problem
Hi
I am also having same problems with this ecart server error. Can you please email me the solution to that or post it so I can figure out what to do? There was no solution attached to the thread. Thanks
This error often means you have deleted or moved the shopping cart file and the page is still trying to access a cart that no longer exists.
The solution is often to re-create the cart with the same name from a blank page on the site.
rob75685
This post has been deleted.
rob75685
Same for me...
hi guys
Same error for me... have tried Ray's suggestion of creating a new cart but hasn't made a difference.
DW CS4, eCart 6, Mac OS 10.6.8
Can you help please ?
thanks
try deleting the WA_DMCFG.xml file from the WA_eCart folder.
if the problem persists, send a copy of the page where you are getting the error and steps to reproduce.
rob75685
thanks Jason - no difference, still getting the error
pages attached, thanks for your help
sorry - to reproduce try deleting some of the content on the page... like one of the DIVs in the middle
Try adding the following code block just before the doctype tag:
// WA eCart Redirect
if ($eCart1->redirStr != "") {
if (function_exists("rel2abs")) $eCart1->redirStr = rel2abs($eCart1->redirStr,dirname(__FILE__));
header("Location: ".$eCart1->redirStr);
die();
rob75685
that's it !
awesome thanks again Jason :)
