Delete Modal Window too high
Thread begun 6/06/2013 11:59 am by Daryl | Last modified 6/06/2013 12:38 pm by Jason Byrnes | 3144 views | 5 replies |
DarylBeta Tester
I have a website that I have created using Twitter Bootstrap with a Static Menu Bar.
I have used data assist to create a delete page and have added it as a plugin to my page.
When I click on delete, the modal window is obscured by the menu bar and the dark screen doesnt go all the way to the bottom of the page.
Any ideas how I can fix this please?
DarylBeta Tester
Correction
Sorry, I didnt use a plugin on this page, I applied a theme using the Framework Theme function
you would need to edit the css, most likely there is conflicting css on the page causing the prblem.
DarylBeta Tester
Details are in the private message.
DarylBeta Tester
if i change the css to
.messageContainer
position: relative;
from postion: absolute;
will it cause me any other problems that you are aware of as it seems to fix it.
that should do fine.
