captcha validation
Thread begun 6/23/2013 8:23 pm by tom439449 | Last modified 6/25/2013 4:26 pm by tom439449 | 4476 views | 4 replies |
tom439449
captcha validation
I am trying to validate the captcha attempting to use the tutorial at: http://assets.webassist.com/html-help/331/form_toolkit_validations_captcha.html. On the form, action=p_thankyou.php. I get the captcha to insert on the form without a problem (I think).
I'm assuming I have to add the validation code to "p_thankyou.php" but I don't see Security_Code_1 from the posted form or any posted form elements at all as seen in the 4th screen shot of the tutorial. I only see the session variable and if you set the session variable = to the session variable instead of the form POST it will always validate.
I have attached both files. The captcha is on p_contact.php but I have removed the but the flawed validation from p_thankyou.php
What am I doing wrong?
on the p_thankyou.php page, go to the bindings panel and click the plus button. select form data, then select the p_contact.php page.
this will add the form bindings or the contact page to the thank you page.
tom439449
Thanks-- works great. I wish that would have mentioned in the tutorial though.
Another question about if the captcha is incorrectly entered, I have it take you right back to the contact page and all the fields on the form have been cleared. I know how to re-populate those fields by writing a bunch of php code using session variables etc. but is there an easier way of having the data re-populate the fields?
Thanks!
Use the Validated entries bindings for the initial value of the forms.
see the following tutorial:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=16
tom439449
Works like a champ! Thanks!
