How do I get purchase information to show up at the store so that they are able to complete order?
Thread begun 7/10/2013 10:41 am by Supreme Geek | Last modified 7/12/2013 10:37 am by Supreme Geek | 7091 views | 17 replies |
Supreme Geek
I just created the Cootie Depot for the Military Order of the Cootie, Supreme Headquarters and the purchases go through Authorize.net. When the end user views this page: https://secure.authorize.net/gateway/transact.dll the item information is at the top. However, the item information doesn't show up at supremehqmoc@lotcs.org so that they can complete the order. All that shows up is the amount of the purchase. I contacted Authorize.net and they don't have a solution, since the items do show up on the purchase page. Please HELP!
I Dont follow, can you please provide more details.
Supreme Geek
More Information
Jason,
Supreme Headquarters, the ones that fill the orders of the items purchased, don't get all of the information sent to them at the e-mail address that is listed in the code on the confirm page. If the item is a simple order such as a pin, the item shows up. However, if the item is a hat that has multiple attributes, such as: Hat Size, Pup Tent Number, Grand, Wording on the Back of the Hat or Years Served those items don't come through when the e-mail is generated. Here is the Purchase page where the end user fills in the credit card information: https://secure.authorize.net/gateway/transact.dll. Here is the Confirm Page that lists the specifics of the item ordered: http://lotcs.org/confirm.php. As you can see, the Hat Size, etc. don't show up on the Purchase page. So, they don't get e-mailed to Supreme Headquarters so that they are able to fill the order. Attached is my confirm.php page. Please let me know what I'm doing wrong here. Thanks...
the item information is sent to authorize.net using the Full Details cart calcualtion
in the cart object, go to the calculation tab.
by default the ful details caclulation is:
[Quantity] . ' ' . [Name] . ' (' . [ID] . ')'
this passes the quantity, Name and ID number.
you can edit that to include other columns, for example:
[Quantity] . ' ' . [Name] . ' ' . [PupTentName] . ' ' . [PupTentNumber] . ' (' . [ID] . ')'
Supreme Geek
Cart problem
Jason,
I put all the variables in like you indicated and I re-put the cart.php on the server. Now I get this error: Parse error: syntax error, unexpected '=', expecting T_STRING or T_VARIABLE or '{' or '$' in /home/content/l/o/t/lotcsadmin/html/WA_eCart/eCart1_PHP.php on line 12. Here's the code:
Attached is the file. I'm basically a graphics guy. Code is not my strong suit. So, if you can tell me what to plug in on line 12 I would appreciate it.
Thanks,
in the eCart object, what is the full calculation you entered?
Supreme Geek
Full Calculation
Hey Jason,
Here is the full calculation: [Quantity] . ' ' . [Name] . ' ' . [PupTentName] . ' ' . [PupTentNumber] . ' ' . [Size] . ' ' . [Grand] . ' ' . [TasselColor] . ' ' . [BackOfHatWording] . ' ' . [Title] . ' ' . [YearsServed] . ' ' . [NeckSize] . ' ' . [CootieName] . ' ' . [CootieNumber] . ' ' . [SleeveLength] . ' ' . [Color] . ' (' . [ID] . ')'
Thanks,
It looks like you have another calculation that does not have a name or contents.
try to make a selection bellow the full details calculation, if you can, there is an empty calculation there that needs to be deleted.
Supreme Geek
Thanks Jason! Now it works. However, on one of my items, the price doesn't show up when I add it to the cart. It shows $0.00. When I went to the bindings tab it showed the proper price of $105.00. Attached is the hats.php file.
Thanks again for your help.
