Checkout page does not work
Thread begun 8/05/2013 6:20 am by rolf358571 | Last modified 8/06/2013 8:58 am by Ray Borduin | 2762 views | 5 replies |
rolf358571
The error is
Notice: Undefined variable: eCart1 in /srv/121.50.207.254/checkout.php on line 6 Fatal error: Call to a member function IsEmpty() on a non-object in /srv/121.50.207.254/checkout.php on line 6
The address to place an order and try the cart is http://121.50.207.254/Covers/Classic.php
Best regards
Rolf
This usually happens when the cart include files are placed too low on the page, or if you name a recordset or other variable with the same name as the cart object. If you attach a copy of the page then I can take a look and be more precise.
rolf358571
Hi Ray. Thank you for your help.
Not sure if you needed the shopping cart page or checkout page so have attached both.
The issue is on the checkout page... move lines 11-16 (not all of line 16, just up to and including ?>)
and paste it on line 1. That should fix your problems.
The wizard is not re-entrant, so if you want to make changes you either have to delete your pages and start over, or make the changes on the pages directly with dreamweaver outside of the wizard. What change are you trying to make?
rolf358571
That fixed the problem. Very appreciated.
Hard to find problems like that when you are not an expert. It was created by the wizard and no changes by me.
When you do the wizard the fist time, there is always things that need changes after you have seen the result. Have a look at the attached checkout page and you will see that it looks silly. I have attached a template to the page after it was created as the wizard grey'd out the option of template.
For example, the lower part needs to flow at the same margin as above section. As everything is done in css and I am not very good at that part, makes it very hard to change things without stuffing up something else.
Also attached confirm page before template addition.
Bye the way, how do I do one drop down box dependent on another. For example, state and country where I want the states of Australia show up when I select Australia. I need this feature in other dropdown boxes too.
While I am asking a lot, where and how do I change the size of dropdown boxes. They are too large when using a small font next to them.
Sorry to be a pain.
Best regards
Rolf
You should check out our tutorial on using Firebug. If you aren't good at CSS it can be a real life saver: [link]http://www.webassist.com/tutorials/Using-Firebug[/link]
There is an extension that comes with Data Bridge specifically designed to help with dependent dropdown lists. The feature is called "Dynamic Dropdowns", so you should find that in the help documentation and it should tell you the steps you would need to follow to make that update.
