Need Multiple Upload!
Thread began 3/25/2009 3:06 pm by meister281653 | Last modified 3/26/2009 8:16 am by Danilo Celic | 2801 views | 3 replies |
meister281653
Hi there,
I need a multiple upload, like in all those social networks.
Denis
Danilo Celic
You can use Digital File Pro for uploading as many images as you'd like, but you would have to apply it one time for each file field on your page.
It would even be possible to upload multiple files from a "single" file field by dynamically creating new file fields using JavaScript, and then you could loop over the available file fields and run the DFP code on each file. But all that's not built in, you'd need to code the filed creation and the looping yourself.
meister281653
Cool,
who does that work?
Danilo Celic
If you don't want to or can't at this time, you can try posting in the Job Board forum to see if someone is able to help you accomplish.
