Fatal error issue on Email PW Page
Thread begun 8/27/2013 6:59 am by hbibizadeh396670 | Last modified 8/27/2013 11:23 am by Jason Byrnes | 3235 views | 8 replies |
hbibizadeh396670
I am getting this error on my email pw page
Fatal error: Call to undefined function wa_securityassist_definition() in /home4/siteezy/public_html/ecommercewebsite/UserRegistrationSystem/EmailPW.php on line 63
Here is my Code:
<?php require_once("../WA_SecurityAssist/WA_SHA1Encryption.php"); ?>
require_once("../WA_SecurityAssist/WA_RandomPassword.php");
<?php require_once('../Connections/localhost.php');?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once('../Connections/Connection.php'); ?>
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
<?php if (!function_exists("GetSQLValueString")) {
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_NewUserPassword = "-1";
if (isset($_POST['emailAddress'])) {
$colname_NewUserPassword = $_POST['emailAddress'];
mysql_select_db($database_Connection, $Connection);
$query_NewUserPassword = sprintf("SELECT * FROM siteezyeceusers WHERE UserEmail = %s", GetSQLValueString($colname_NewUserPassword, "text"));
$NewUserPassword = mysql_query($query_NewUserPassword, $Connection) or die(mysql_error());
$row_NewUserPassword = mysql_fetch_assoc($NewUserPassword);
$totalRows_NewUserPassword = mysql_num_rows($NewUserPassword);
$query_Design = "SELECT * FROM siteezyecdesign";
$Design = mysql_query($query_Design, $Connection) or die(mysql_error());
$row_Design = mysql_fetch_assoc($Design);
$totalRows_Design = mysql_num_rows($Design);
$query_AdminEmail = "SELECT * FROM siteezyecadminpaypal";
$AdminEmail = mysql_query($query_AdminEmail, $Connection) or die(mysql_error());
$row_AdminEmail = mysql_fetch_assoc($AdminEmail);
$totalRows_AdminEmail = mysql_num_rows($AdminEmail);
function WA_SecurityAssist_Email_1_SendMail($WA_Auth_Parameter){
$WA_MailObject = WA_SecurityAssist_Definition("","25","","","");
$WA_MailObject = WA_SecurityAssist_SendMail($WA_MailObject,"","","",$WA_Auth_Parameter["toAddress"],"",$WA_Auth_Parameter["fromAddress"],$WA_Auth_Parameter["subject"],$WA_Auth_Parameter["mailBody"]);
$WA_MailObject = null;
}// WA_SecurityAssist_Email_1_SendMail
if(isset($_POST["Send"]) || isset($_POST["Send_x"])){
//WA SecurityAssist Email object="mail"
$WA_Auth_Parameter = array(
"connection" => $Connection,
"database" => $database_Connection,
"tableName" => "siteezyeceusers",
"filterColumn" => "UserEmail",
"filterEncryption" => "",
"columnValue" => "".((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") ."",
"columnType" => "text",
"usernameColumn" => "UserName",
"usernameEncryption" => "",
"passwordColumn" => "UserPassword",
"passwordEncryption" => "",
"selectColumns" => array("UserName","UserPassword","UserEmail"),
"sessionVariables" => array(""),
"successRedirect" => "LogIn.php",
"failRedirect" => "EmailPW.php",
"keepQueryString" => FALSE,
"toAddressColumn" => "UserEmail",
"toAddressEncryption" => "",
"fromAddress" => "".$row_AdminEmail['EmailFromAddress'] ."",
"fromAddressDisplay" => "".$row_AdminEmail['EmailForm'] ."",
"subject" => "Forgot Password",
"mailBody" => "Dear [UserFirstName] [UserLastName],
Please use the details below to access your account
User name: [UserName]
Password: [UserPassword]
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
that function is defined in the webassist/security_assist/mail_php.php
the error suggests that that file is not uploaded. make sure to upload the entire webassist/security_assist/ folder to the server.
NOTE: instead of pasting the page code to your message, please compress the page to a zip file and attach the zip file.
hbibizadeh396670
Thank you.
I am now getting this
Warning: Missing argument 6 for WA_SecurityAssist_Definition(), called in /home4/siteezy/public_html/ecommercewebsite/UserRegistrationSystem/EmailPW.php on line 63 and defined in /home4/siteezy/public_html/ecommercewebsite/webassist/security_assist/mail_php.php on line 34
Warning: Cannot modify header information - headers already sent by (output started at /home4/siteezy/public_html/ecommercewebsite/webassist/security_assist/mail_php.php:34) in /home4/siteezy/public_html/ecommercewebsite/webassist/security_assist/helper_php.php on line 142
edit the forgot password sever behavior and make sure to select a character set.
hbibizadeh396670
Sure, would you mind explaining what a character set is.
There are a lot of options and I have not come across this before. Just want to make sure I use the correct one. Thanks
hbibizadeh396670
This is just not working. I even made a new page, and added the code. Nothing.
I did the character set to UTF-8
I no longer get errors, just the page reloads and in the url I get EmailPW.php?notFound=true
I have attached all files
In the Email Password server behavior, you hca the filter column set to the ID column, it needs to be set to the email address column
also, you are using a recordset binding for the email address, you should be using the form binding.
hbibizadeh396670
I made the changes
I now get this error
Warning: Missing argument 6 for WA_SecurityAssist_Definition(), called in /home4/siteezy/public_html/ecommercewebsite/UserRegistrationSystem/EmailPW.php on line 64 and defined in /home4/siteezy/public_html/ecommercewebsite/webassist/security_assist/mail_php.php on line 34
THanks
find the following line:
and change it to:
$WA_MailObject = WA_SecurityAssist_Definition("","25","","","","");
