DataAssist Search Page Multi Submit Buttons
Thread begun 8/17/2009 10:23 am by Intrigue25 | Last modified 8/21/2009 3:59 pm by Jason Byrnes | 6413 views | 10 replies |
Intrigue25
Hello,
I have a DataAssist Search page i created with a dropdown box and I am viewing the results on the same page. I needed to modify the code to have 2 buttons on the form. 1 to display the results ( on the same page as the dropdown search box) the other to send the varaible to a export page that allows my client to export the selected database into a excel spreadsheet. I have everything working fine except the search page is not refreshing the results after i choose from the dropdown box.
I am using the Javascript below to activate the two buttons.
<script language="Javascript">
function OnButton1()
document.bListSearch.action = "search.php"
document.bListSearch.submit(); // Submit the page
return true;
function OnButton2()
document.bListSearch.action = "export.php"
return true;
</script>
Here is the form....
<form name="bListSearch" method="post">
<table cellpadding="2" cellspacing="0" border="0">
<tr>
<td align="right"><label for="birthdayMonth">Keywords</label></td>
<td><select name="birthdayMonth">
<option>All</option>
<option value="June">June</option>
<option value="August">August</option>
</select></td>
</tr>
<tr>
<td align="center" colspan="2">
<INPUT type="button" value="Submit" name=button1 onclick="return OnButton1();">
<INPUT type="button" value="Export" name=button2 onclick="return OnButton2();">
</td>
</tr>
</table>
Any help would be appreciated
What is the trigger for Database search on either the export or search pages?
Try clicking the lightning bolt next to trigger. In the Dynamic Data Bindings, expand the form and select the birthdayMonth select list as the trigger.
Intrigue25
That worked! But...
Thanks Ray
One more question. How do i get the dropdown menu to display all the recordeds?
My Dropdown reads.
Value Label
All
June June
July July
August August etc...
I would like all to show all the record in the table when selected.
Thanks in Advance
The value for the all option must be a blank string:
[html]<option value="">All</option>[html]
Intrigue25
Display All records .. Not Working
Jason
Thanks Again for all your help. But i had that in my dropdown box. Here is the code
In my DataAssist Search Wizard I am doing a Exact Match. Is that problem?
If so what other search element should i do? I have attached a screen shot of the dataAssist wizard and below is the Dropdown list code i have in place
<option value="" selected>All</option>
<option value="January">January</option>
<option value="February">February</option>
<option value="March">March</option>
<option value="April">April</option>
<option value="May">May</option>
<option value="July">July</option>
<option value="September">September</option>
<option value="October">October</option>
<option value="November">November</option>
<option value="December">December</option>
</select>
That should work, can you post a link to your page?
Intrigue25
File
Jason,
Sorry i can not post a link to the page because Its a live site and that page is in a Secure Area, but i have attached the page to this Thread so you can look it over.
Please let me know if you need anything else.
(P.S. I have no problem doing this off the forum)
thanks
Chad
Intrigue25
Sorry - Wrong File
Jason,
I attached the wrong file to the last post. Please disreguard that file and use the one attached to this post.
The problem is that the search is triggered on the birthdayMonth form element being set and not equling a blank string.
If it equals a blank string, it will end up using the last search you preformed.
try changing:
if ((((isset($_POST["birthdayMonth"]))?$_POST["birthdayMonth"]:"") != "")) {
if (isset($_POST["birthdayMonth"])) {
Intrigue25
Didn't seem to Fix
Jason,
I tried changing that line of code and i am getting the same results.
