I am having trouble inserting a record
Thread begun 9/12/2013 4:15 pm by ericbass213433382 | Last modified 9/13/2013 10:11 am by ericbass213433382 | 1562 views | 5 replies |
ericbass213433382
I am having trouble inserting a record. I would also like to upload an image in one of those fields. I cant get it to upload anything.
Im sure you will have me sorted out quick fast and in a hurry. Thanks in advance.
For file upload to work, the forms encoding type must be set to multipart/form-data
in the tag selector, select the form tag, then in the property inspector, change the encoding type to multipart/form-data.
ericbass213433382
Thanks, however that didn't fix it
I cant find where to bind the values in the the insert dialog. The form doesn't come up to pick.
I changed what you said above but it still isnt working. Thanks Advance.
insert.zip
your form elements are not valid. for example:
<input name="order_num">
is missing the ID, type and value attributes:
<input name="order_num" id="order_num" type="text" value="">
ericbass213433382
Thank you ! 1 last for this topic
what is the binding for the image
ericbass213433382
I figured it out
Thanks Jason!
