What tutorials should I use to set up my store. I can't find anything current for setting up the pages using my template and using eCart to set up the functionality.
Thread begun 9/18/2013 9:31 am by russb335115 | Last modified 11/21/2013 12:20 pm by Jason Byrnes | 12477 views | 59 replies |
russb335115
I'm trying to find tutorials for setting up a store section on my clients website. I have the current version of Supper Suite to work with
Look at the eCommerce series, the first one in the series can be found here:
http://www.webassist.com/tutorials/Create-a-product-catalog-eCommerce-Series
at the end are links to the other tutorial in the eCommerce series.
russb335115
Thanks Jason,
I will check them out,
Best regards
russb335115
eCart
Hi Jason,
I get this error when going through the tutorial that you recommended at the point where I'm at the "click on Look up item ID from recordset" in the "Create an Add to Cart Button".
See attached image
send a copy of the page you are trying to add the add to cart behavior to
russb335115
I have attached the file
What extensions do you have installed? including the version number.
have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
russb335115
here they are:
WebAssist Free Tools 1.0
eCart 5.0
Design Extender 1.1
Data Bridge 1.1
I will try to delete the Dreamweaver Cache file and see if that helps ( I had done this recently by your instruction for another issue and reinstalled all Webassist products )
russb335115
try to delete the file, that was no help I am still getting the error and it won't let me proceed any further.
all of those extensions have been updated to newer versions.
Uninstall all 4, then download the newer versions and install in this order:
eCart 5.0.7
Free Tools 1.0.5
Design Extender 1.1.5
Data Bridge 1.1.4
