Show textarea if checkbox is checked?
Thread begun 10/14/2013 1:41 am by Nathon Jones Web Design | Last modified 10/16/2013 9:58 am by Nathon Jones Web Design | 13025 views | 8 replies |
Is it possible to hide a textarea until a user puts a check in a checkbox using Validation Toolkit or does a Submit button need to be pressed?
Here's an example on a site we're developing:
http://www.nathonjones.com/babyfish2013/personalised-baby-toddler-gifts.asp?BFid=BF570
Thanks for any advice offered:
NJ
here is a very basic example to demoinstrate how this can be done:
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<script>
function toggleTextArea() {
var theForm = document.form1;
var theCheck = theForm.checkbox;
var theTextArea = theForm.textfield2;
if(theCheck.checked == true) {
theTextArea.style.display = "block";
} else {
theTextArea.style.display = "none";
</script>
</head>
<body>
<form id="form1" name="form1" method="post" action="">
<label for="textfield"></label>
<input type="text" name="textfield" id="textfield" />
<input name="checkbox" type="checkbox" id="checkbox" onchange="toggleTextArea();" value="1"/>
<label for="checkbox"></label>
<label for="textfield2"></label>
<textarea style="display: none;" name="textfield2" rows="8" id="textfield2"></textarea>
</form>
</body>
</html>
IE8
Thank you Jason. That doesn't work in IE8, but I assume it works in all modern browsers.
Is there a way to hide the label text until the checkbox has been checked or can you only hide/reveal the textarea itself?
Really appreciate it. That's the only real hold up with this project.
Thank you, again.
NJ
you could put the text area into a span, and have the JS function change the style of the span by ID.
<head>
<script>
var theTextArea = document.getElementById('textAreaSpan');
} else {
</script>
</head>
<body>
<span style="display: none;" id="textAreaSpan"><label for="textfield2">label for text area</label>
<textarea name="textfield2" rows="8" id="textfield2"></textarea></span>
</form>
</body>
</html>
Great stuff!
Really great help, thank you Jason.
NJ
you're welcome.
IE
Sorry, that's not working in Internet Explorer I just realised! Have tried it in IE8 and IE10.
What happens is that the textarea doesn't display until you click somewhere else on the page.
Have I done something wrong or were you aware of that incompatibility?
Thank you.
NJ
I think early IE versions have an issue with the onchange event when used with checkboxes and radio buttons, try using onclick instead.
change:
onclick="toggleTextArea();"
IE
It wasn't working in IE10 either. Onclick has resolved it though. Much appreciated.
NJ
