kCFError 303
Thread begun 11/19/2013 9:30 am by gyske292158 | Last modified 11/19/2013 9:40 pm by Jason Byrnes | 5519 views | 5 replies |
gyske292158
kCFError 303
After building Users management pages as mentioned in your tutorials (blue sky record shop) I want to see the resulting pages on my Mac (Powerbook 10.8.5).
After uploading them to my http://localhost/~user/companyPages/ I want to see user.insert.php.
Using the preview in browser from the File menu, Safari (6.1) reacts with a new tap. (my preference)
But instead of showing the user,insert,php I get a page with:
Safari can't open the page
Safari can't open the page "http://localhost/~gyske/HavasoSculpture-Server/user.insert.php". "The operation couldn't be completed.
(kCFErrorDomainCFNetwork error 303.)" (kCFErrorNetwork:303)
A search on the web delivered no answer what to do against it, except trowing away the safari preferences as I tried without success.
Also I restarted, repaired the system with fsck, what told me all ok.
If I try to load the user.search.php I get the page, but as soon as I ask for a search (a record I know it's there or not) I get again the kCFErrorNetwork:303 error.
Do you know how to overcome this?
please send a copy of the insert page.
gyske292158
Please find he insert page attached.
all of the include files are using the virtual function, for example:
<?php virtual('/~gyske/HavasoSculpture-Server/Connections/connBlueSkyMusic.php'); ?>
The Virtual function is not supported by most PHP servers.
DW Uses the virtual function for include files if you you set the Site to create links relative to the server.
In the site definition, you should set the option for creating the links to use the document instead of the server, this will cause DW to use the require_once function for the include files.
it is the use of the virtual function for the includes that is causing the error.
gyske292158
Following your suggestions it worked, my kCFError 303 has gone.
you're welcome.
