Ecart checkout only accept one order
Thread begun 12/25/2013 4:22 pm by henrik441511 | Last modified 12/30/2013 9:16 am by Jason Byrnes | 4850 views | 13 replies |
henrik441511
Hi
Where can i reset Ecart for same customer after checkout so that this customer when directed back to Ecart can make a new order?
with a new orderID. As it is now i have to logout and login to make a new order
Regards
You can use the "clear session values" server behavior on the Checkout Success page to clear the shopping cart and the OrderID session variables.
Once you apply the server behavior you will want to move the code to the bottom of the page so that you can still show the cart contents on the page before they are cleared.
The new eCart 6 checkout wizard will do this automatically.
henrik441511
Thank but did not work! if i clear all sessions i also get logged out and customer have to log in again and i am back to the same problem i have,
placed here? trigger Button: Checkout pressed or use another trigger
Tried, to only use some clearances
@session_start();
if (isset($_POST["Checkout"]) || isset($_POST["Checkout_x"])){
// WA_ClearSession
$clearAll = FALSE;
$clearThese = explode(",","WADA_Insert_products,WADbSearch1_products_results,WADbSearch1_orders_results");
if($clearAll){
foreach ($_SESSION as $key => $value){
unset($_SESSION[$key]);
else{
foreach($clearThese as $value){
unset($_SESSION[$value]);
Can you send me a manual for Ecart can only find an old one Ecart 4 and still there it did not say anything about all variables/ session
or any ideas which session variables to remove?
It have placed itself right before <html> what do you mean with place on bottom then is it after </body> or what?
it also did not clear ecart, do i have to clear that too by myself?
Actually i got it a kind to work. It updates the same record count by one when it is the same item but not a new item it can handle in a new order record is set up it stays the same?
SHALL I REMOVE EVERYTHING AND START AGAIN FROM BEGINNING?
Don't start over.. it won't help.
Move the code after the </html>
The session variable that holds the cart contents is called [cartname]_Items
Replace [cartname] with the name of your cart and add that to the Session variables to be deleted and the cart will be cleared as well.
henrik441511
I tried to follow YOur instructions but now not even one cart shows in ordertable.
Have been looking after session [cartname]_Items but it does not exist? [eCart1]_Items
my cart name is Ecart1, how come?
just eCart1_Items... no brackets. Add it to your Session bindings manually and then you will be able to select it as a variable to be removed, or add it to the code manually:
$clearThese = explode(",","WADA_Insert_products,WADbSearch1_products_results,WADbSearch1_orders_results,eCart1_Items");
henrik441511
Many thanks it work. and great you are there to help for us newcomer.
The server behaviors will not show if you hand edit the code... so the line you said you changed is also the reason it doesn't show.
To get the new orders to insert, change the code back so that you can open the server behavior.
Then open the Store Cart Summary in Database server behavior and find the value for the Save As field. That is the session variable name where the order id is stored. If you add that to the list of server behaviors to remove it will add second orders placed in the same session.
henrik441511
I have changed everything back.
I think it is the "store as field" nope i can only update one record, even with session variable orderid in the clear session,
the only way i can make i work is handcode $NeedInsert = (mysql_num_rows($result) === 0); set to 1
Last thing. If i want to store the productID as well in the order table is it ok to use the cart ID?
Yes, the cart ID field is usually set to the product ID. Usually that would be set in the OrderDetails table since more than one item could be in the cart.
