eCart 6 causing missing files in Configuration/Floaters directory
Thread begun 1/16/2014 9:21 am by phil287111 | Last modified 1/16/2014 4:34 pm by phil287111 | 4167 views | 5 replies |
phil287111
I just purchased eCart 6 and have installed it in Dreamweaver CS5 after uninstalling eCart 5. When I close and reopen Dreamweaver I get a series of popups telling me that it can't find certain files in the Configuration/Floaters directory and the floater will not be shown. I also get a message about a Javascript error where it can't open WA_Configuration.js.Is there a fix for this? I've been using eCart since version 2 and haven't had this problem upgrading in the past.
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
when you open DW, open a PHP page to start the WA Installer. The WA Installer will finish installing the eCart extension.
phil287111
That cleaned up the issue with the 'floater' errors, thank you. Now I just have a message saying that there is a JavaScropt error: Unable to open C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS5\Configuration\WA_Installer\Library2\WA_Configuration.js. I hope this one is as easy as the other!
we found a problem with the WA installer, will are comping new builds to address the problem as I type this and they should be available latter today. I will let you know when that happens.
New Dot releases have been uploaded to the download section for:
eCart 6.0.1
these versions should correct the problems you are having.
uninstall the previous versions from the extension manager, then install the new ones
phil287111
Thanks Jason, for your quick response to fix this.
