I'm getting an error when editing a form in databridge
when i go to insert a form and then i click on edit the form it gives this error.
We updated the WA installer for Data Bridge to correct this.
Uninstall Data Bridge in the extension manager, then Re install it, the WA Installer will run when you start up dreamweaver and open a php page, the updated installer files should correct this issue.
I tried removing it and re installing it and also in different order because we also have ecart and still the same error....i tried removing cache...i tried resetting the work space and i even saved all the presets and removed it and removed the webassist folder from the system shared folder and the error is still there
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
