Map location titles
Thread begun 3/26/2009 12:25 pm by todd368532 | Last modified 3/27/2009 12:12 pm by Ray Borduin | 4424 views | 3 replies |
todd368532
Map location titles
This is such a nice tool, it seems really odd that all it shows is an address. Is there a way to add something into the code to show the name of the location? Business name, restaurant name, whatever? What's the sense in showing multiple locations and not have any indication of what that location is. Help a kid out.
TJ
There are lots of options for what you might do. What exactly are you trying to do? We would need to start there.
Are you using a database?
todd368532
Yes, I have a MySQL database going, connects fine. What I want is to show not only an address, but the name of the business as well. It's a Chamber of Commerce member map showing locations of each member business.
You could use the recordset to create a display of each location on the html page below the map and link it to the corresponding location. I haven't done this, but it should also be possible to add recordset references into the info window directly. Have you tried anything? Sometimes creating web pages is about trying things and debugging the result.
