Add to Cart Button for Individual DataAssist Results Page Items
Thread begun 2/07/2014 8:28 am by Mike Perry | Last modified 2/10/2014 7:18 am by Jason Byrnes | 1829 views | 3 replies |
Mike Perry
Is there a better way to do this?
I need individual Add to Cart buttons for a DataAssist Results page. I created an Add to Cart button in a separate form on the page, then copied the button code into the repeating table code for the results. I changed the main form action to the form action for the eCart burron form, then commented out all unneeded code.
When I click on a button it goes to the mycart.php page, but it sends the ProductID for the last item in the page recordset, not picking up the $row_WADAproducts["ProductID"] variable (10 items / page).
Page code is attached -- thanks,
Mike
you need a form around each add to cart button.
before adding the add to cart, remove the form that is around the repeat region.
then add the add to cart button behavior to the results page.
this tutorial has details on adding the add to cart to the results:
http://www.webassist.com/tutorials/Create-a-product-catalog-eCommerce-Series
Mike Perry
Got it -- thanks, Jason. . .
you're welcome.
