I'm thinking of using Power Messenger for a customer. But have some questions.
Thread began 2/18/2014 11:31 pm by Jonas | Last modified 2/21/2014 9:33 am by Jason Byrnes | 2513 views | 9 replies |
Jonas
If the customer, for example, now has a web hosting provider with, as usual, a certain space. How much does it affect the server? Does the customer need to upgrade their web package?
Is it possible to create highly-designed templates?
Will mailings displayed correctly in all email clients?
Can multiple users manage the account?
Power Messenger does not take up a lot of space on the server. default install is just over 100MB, after you complete the install on the server, you should delete the install_cms folder, this will save some space but should be well within the space requirements of most hosting packages.
Power Messenger contains 100 predefined email templates that you can use a s basis for creating your mailing.
We chose these templates based on the compatibility with various mailing clients. it is impossible to say that they will "displayed correctly in all email clients" since there are still text based clients in use that do not support HTML mailings. these clients will still show the email, but it will be a stripped down, no html version of the email.
yes, you can have multiple administrators managing the emails.
Jonas
Thanks for your reply Jason
you're welcome.
Jonas
A question about templates included. Is it possible to view images on the templates in advance?
We do not have a preview of the templates available, but that design should be fairly strait forward to accomplish.
Jonas
ok sounds good.
you're welcome.
Jonas
Our web hosting provider says that you have to create an isolated environment through the VPS to Power Messenger to work. Is this correct?
Depends on the hosting provider.
Since Power Messenger can be used to send out large mailings, some hosting providers may not like that to happen on a shared environment where your mailing would interfere with other customers since the web server resources are shared.
