Need Help, Nothing working it webassist menu after install. running Dreamweaver CC
Purchased, downloaded Databridge Upgrade and installed. Webassist menu(s) show in Dreamweaver CC but nothing happens when clicking them.
Please help.
Please help.
After installing the Data Bridge extension, when you open DW, it should launch the WebAssist installer to complete the installation.
if the web assist installer does not open, open a php page, that should trigger the installer to open and finish installing.
once the webassist installer completes, make sure to restart DW.
Hi Jason,
The installer did run and it finished. When it finished I shut everything down and re-started the computer. this was prior to posting my problem.
to add, I"m running a Mac OS X 10.8.5
Try uninstalling Data Bridge from the extension manager, then installing it again. Also, make sure that you have the deprecated server panel extension installed:
http://www.webassist.com/tutorials/Server-behaviors-for-Dreamweaver-Creative-Cloud
re-installed twice - third install finally worked.
thanks for the help
glad to hear it is working.
