Wrong template in email sending
Thread begun 2/26/2014 9:33 am by Jonas | Last modified 2/26/2014 10:19 am by Jason Byrnes | 2999 views | 5 replies |
Jonas
I have created a contact form with the help of Design Extender 1.1.7 Form tool.
The email that is sent using the wrong template.
I've renamed the template and corrected some details in the file. Then I have chosen the template again in the contact file from Universal Email. The image shown is the right template. I've also double checked the code to the form. It refers to waue_kontakt_1.php. Which in turn refers to templates/kontakt.php. Which is the correct file. But the mail that arrives using the old template.
Jonas
thanks
on the sv/kontakt.php page, the action of the form is to post to the kontakt-fel.php page
<form class="Egen_Kontakt1spalt" id="Skickameddelande_Egen_Kontakt1spalt" name="Skickameddelande_Egen_Kontakt1spalt" method="post" action="kontakt-fel.php">
the UE instance on that page connects to the webassist/email/waue_kontakt-fel_1.phppage
include("../webassist/email/waue_kontakt-fel_1.php");
and the template used by that page is the Blank_16.php
$MailBody = $MailBody . (GetFromPage("templates/Blank_16.php"));
Remeber that all form processing must happen on the forms action page.
if you wish the form on the kontakt.php page to use the UE instance that is on that page, you must change the forms action to do so.
Jonas
I understand in part.
The page 'kontakt fel.php' is an error page that is only supposed to appear if it goes wrong.
The page 'kontakt tack.php' is a thank you page to be displayed if everything is right.
Can I choose both thank you page and error page in the UE on the contact page, or do I need to do this, on the thank you page? What should I choose in 'failed redirect' on the contact page?
you have a number of problems in the way this is set up.
your form should be set to post to the kontakt.php
the validation and UE behavors should only be on the kontakt.php page, you have them on the kontakt fel.php page as well
in the server validation on the kontakt page, set the failed redirect to the kontakt fel.php page (This is already done)
in the UE behavior on the kontakt.php page set the Go TO to go to the thank you page (this is also already done)
