Fatal Error
Thread began 2/27/2014 6:28 pm by Eric Goodman | Last modified 2/28/2014 10:11 am by Jason Byrnes | 1628 views | 10 replies |
Eric Goodman
Fatal Error
I am getting an error on a new CMS site I am setting up. Everything seemed to be running smoothly when doing the operations. When I went to the URL I am getting the following:
Warning: require_once(../images/installed.jpg) [function.require-once]: failed to open stream: No such file or directory in /home/content/p/r/i/printmedia/html/WA_Globals/WA_Globals.php on line 59
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.jpg' (include_path='.:/usr/local/php5/lib/php') in /home/content/p/r/i/printmedia/html/WA_Globals/WA_Globals.php on line 59
Eric Goodman
Got Fatal Error again - See PM
see PM
Eric Goodman
See PM
PM
see PM
Eric Goodman
PM
See PM
see PM
Eric Goodman
Much appreciated
I will be sure to watch my naming conventions in the future. Thank you again!!!
you're welcome.
