list combined with static option
Thread begun 3/09/2014 9:04 am by mike-j-taylor318947 | Last modified 3/10/2014 6:48 pm by Jason Byrnes | 3900 views | 9 replies |
mike-j-taylor318947
Hi, I have a static cart with a select list on the price so when 1 of 10 items are selected it adds the correct price to the cart, I wondered is there a way to get the information in the list displayed on the cart page, the reason for this is at the moment say 4 items are selected from the list then they appear, with different prices as wanted and they all add up to the total but it does not tell the customer the size of the item for the price that they saw in the list when making the choice from the catalogue page.
below is the code and from the list item I would like the sizes to appear 75cm Fine-3mm and so on in the cart when they have been added, also attached is an image to show what it displays at the moment
Code for list:
<h2>BLACK <img src="../../images/laces/waxed laces/thumb/WL_black_thumb06.JPG" width="200" height="150" alt="Fine black"><br>
<form name="InsoleCart_1_ATC_0" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="InsoleCart_1_ID_Add" value="0" >
<input name="InsoleCart_1_Quantity_Add" type="text" value="1" size="4">
<select name="InsoleCart_1_Price_Add" size="1">
<option value="2.99" selected>75cm Fine-3mm</option>
<option value="2.99">75cm Heavy-5mm</option>
<option value="3.50">100cm Fine-3mm</option>
<option value="3.75">100cm Heavy-5mm</option>
<option value="3.75">120cm Fine-3mm</option>
<option value="3.75">120cm Heavy-5mm</option>
<option value="3.99">140cm Fine-3mm</option>
<option value="4.10">140cm Heavy-5mm</option>
<option value="4.40">180cm Heavy-5mm</option>
</select>
<input type="image" value="Add to Cart" name="InsoleCart_1_ATC" src="../../WA_eCart/Images/Pacifica/Btn2_EN_addtocart.gif" border="0">
In the cart object you should have a column for the Size.
Make sure that column is included in the cart display as well.
In the Add to cart button behavior, set the size column to be updatable by a hidden element.
the add a javascript onchange event to the price select list to populate the size hidden element:
from you example, i know the form name (InsoleCart_1_ATC_0) and the select list name (InsoleCart_1_Price_Add), so the on change should be:
onChange="document.InsoleCart_1_ATC_0.<hiddenFieldName>.value = document.InsoleCart_1_ATC_0.InsoleCart_1_Price_Add[document.InsoleCart_1_ATC_0.InsoleCart_1_Price_Add.selectedIndex].text"
where <hiddenFieldName> is the name of the hidden form element.
mike-j-taylor318947
is there a tutorial for this as I have had a go and cant get it to work and to be honest I do not understand it 100%
no, there is not a tutorial
send a link where i can see the problem.
mike-j-taylor318947
I only have it on a testing server and not live so no link, I will keep trying till I work it out
If you need me to troubleshoot, you will need to upload it to a live server.
mike-j-taylor318947
Now I have this but unsure what to do next to get it to work
<select name="InsoleCart_1_Price_Add" onChange="onChange=&quot;document.InsoleCart_1_ATC_0.&lt;Size&gt;.value = ">
</select>
<input type="hidden" name="InsoleCart_1_Size_Add" value="" >
the onchange code is not correct
should be:
onChange="document.InsoleCart_1_ATC_0.InsoleCart_1_Size_Add.value = document.InsoleCart_1_ATC_0.InsoleCart_1_Price_Add[document.InsoleCart_1_ATC_0.InsoleCart_1_Price_Add.selectedIndex].text"
mike-j-taylor318947
its working perfectly, I had missed a line of the onChange out and just couldn't see it, thank you so much for your help
you're welcome.
