Displaying apostrophe’s
Thread begun 3/11/2014 6:50 am by john411474 | Last modified 3/13/2014 8:26 am by Jason Byrnes | 2507 views | 3 replies |
john411474
Hello
Having a problem displaying apostrophes
I upload a csv file thru phpmyadmin
when I browse the table using phpmyadmin the field value is displayed correctly (Boar’s Head)
Table: InnoDB
Table Collation: utf8general_ci
Field Collation: latin_swedish_ci
In web assist search results ‘ appears a solid diamond symbol with question mark inside it
How do I get the apostrophe to appear?
thanks
jr
1) make sure the character set for the page is set to UTF-8.
go to modify -> page properties. in the Title encoding section, set the encoding to UTF-8
2) the connection should be set to use UTF-8 as well. if you used the standard Dreamweaver connection connection you will need to edit the connection file
in the connections folder, openthe connection file, the last line ill look similar to this:
$ConnectionName = mysql_pconnect($hostname_ConnectionName, $username_ConnectionName, $password_ConnectionName) or trigger_error(mysql_error(),E_USER_ERROR);
add this line after it:
mysql_set_charset('utf8',$ConnectionName);
where ConnectionName is the name of the connection.
if you used the Data Assist Dynamic Connection to create the database connection, you can set the character set in the connection settings screen instead of editing the code.
john411474
Editing the connection file fixed the problem
jrt
Glad to hear it is working.
