Red exclamation mark alongside all occurences of eCart object in Server Behaviours window?
Thread begun 3/18/2014 8:12 am by Nathon Jones Web Design | Last modified 3/27/2014 11:16 am by Jason Byrnes | 8665 views | 23 replies |
I have a red exclamation mark alongside all occurrences of the eCart object in Server Behaviours window, across all pages of my site now. When I open the object and then click OK, I get a warning dialogue box stating "This file has been modified outside of Dreamweaver. Do you want to reload it?" I've selected both Yes and No for that without any change to the red exclamation.
Hope you can help
Thank you.
NJ
the red exclamation mark only means that DW is not entirely certain about a code block.
it really just means:
test the page in the browser, there may be a problem, or maybe not. if the page works in the browser, all is good, ignore the red exclamation. If not, there is something to investigate.
recordsets
We're getting the same exclamation marks on our recordsets and frequently receive the following dialog error message:
"While executing applyServerBehaviour in Recordset.htm, a JavaScript error occurred"
That error is preventing us from making changes to our recordsets.
Go to the database tab, and double click the connection. click the test button. does it connect OK?
send a copy of one of the pages with a recordset please.
It connects, yes. We also have a Show If region that's indicating that the field being used isn't in the recordset, yet there it is in the recordset.
Attached below.
"indicating that the field being used isn't in the recordset"
and which field would that be?
please provide complete details.
LEDbrightness
(sorry)
We have this within the following Show if column behaviour on that page:
<?php if ($row_rsPRODFULL['LEDbrightness'] < 4) { // Show if column... ?>
<div class="prodmidspecsm">
<span class="orange">Brightness</span><br>
if ($row_rsPRODFULL['LEDbrightness']=="1")
{echo "<img src='plugins/energy-saving-light-bulbs/brightness/standard.png' alt='Standard Brightness Graphic' title='Standard Brightness' width='75px' height='75px' />";}
elseif ($row_rsPRODFULL['LEDbrightness']=="2")
{echo "<img src='plugins/energy-saving-light-bulbs/brightness/high.png' alt='High Brightness Graphic' title='High Brightness' width='75px' height='75px' />";}
elseif ($row_rsPRODFULL['LEDbrightness']=="3")
{echo "<img src='plugins/energy-saving-light-bulbs/brightness/extrabright.png' alt='Extra Bright Brightness Graphic' title='Extra Bright' width='75px' height='75px' />";}
</div>
<?php } // Show if column... ?>
...yet our recordset has LEDbrightness listed within it.
Harumpff....corrupt WinCache file.
What causes that Jason? It has meant renaming the Configuration folder which removes our extensions. :(
if the wincache file is corrupt, you don't need to rename the config folder, only delete that file with DW shut down.
as for what causes the cache file to become corrupted, that can be any number of things.
Dreamweaver extensions are javascript based. When you open an extension the first time, the javascript is compiled and saved to the cache file. when you open the server behavior again, it uses the compiled script in the cache file. If it compiles the behavior wrong, the cache file becomes corrupted.
on the database tab, expand the connection, then expand the tables and expand the table used in the recordset, send a screen shoot of database tab showing the tables and the columns in the table used in the query, also send a screen shot of the show region issue you mentioned before.
