Advice on creating a product update form - image updating, thumbnail creating, text updating
Thread begun 3/20/2014 5:42 am by Nathon Jones Web Design | Last modified 3/26/2014 1:40 pm by Nathon Jones Web Design | 8380 views | 30 replies |
In a CMS that we're building I'd like to have forms for adding and updating products on a website.
What is the best approach, using WebAssist extensions, in order to achieve this?
We need:
1) Basic text form fields (to add/update thing like the title, price, weight etc)
2) Drop-down menus (that are populated dynamically using recordsets but that retain the correct value should we be editing a product)
3) Textarea form fields that will allow users to enter formatted text with <p> tags for paragraph breaks.
4) File upload form fields that will allow users to upload product photographs (option to create a thumbnail on the fly?)
We've used so many solutions over the years (Interakt, DMXzone etc) and we just want to streamline this into one extension, or one set of extensions, if at all possible.
Would appreciate any advice offered, thank you.
NJ
see the eCommerce tutorial for creating a product catalog, it includes a section for creating the admin pages to insert and update product details:
http://www.webassist.com/tutorials/Create-a-product-catalog-eCommerce-Series
When running the Data Assist wizard to create the product admin pages, in the Field settings section of the manage pages tab, you select for fields to be text areas, lists and file fields. For lists, you can specify them to use another table like categories to populate.
the Data Assist wizard can be configured to create the results, update and insert pages. The results page will have a link to the update page and the update page will be pre populated with the selected record.
I already have my database connection and product catalogue in place which I created without using DataAssist.
I'm simply looking to create two forms...an INSERT product and an UPDATE product form.
Am I going to be able to do this without running through the DataAssist wizard?
Also, I can't see anything in the tutorial you've highlighted about uploading images, creating textareas with formatting etc. It just seems to deal with simple text input fields.
Hope you can direct me to the right place/solution.
Thank you.
NJ
without using the data assist wizard, you will need to do it manually. we don't have a tutorial for this, it would be simpler to use the wizard to create the pages, using the wizard you can configure everything you asked about within the wizard.
The tutorial may not mention anything about file upload, and text areas, but if you become familiar with using the wizard, you will see, as I said in my reply, that they can be easily added:
"When running the Data Assist wizard to create the product admin pages, in the Field settings section of the manage pages tab, you select for fields to be text areas, lists and file fields. For lists, you can specify them to use another table like categories to populate."
I'm happy to work without the DataAssist wizard because it means that I won't have to recreate pages that already exist.
Can you forward instruction on how I create a file upload option using WebAssist extensions?
I also need to insert what I formerly knew as iRite on some textarea fields. What is that called now and how do I access it?
Thank you.
NJ
the tutorial section of our site is searchable
go here:
in the keywords section enter:
"file upload"
the first 2 results are:
http://www.webassist.com/tutorials/Add-file-fields-to-Data-Bridge-insert-update-pages
http://www.webassist.com/tutorials/Apply-file-upload-or-download
iRite is now HTML editor, see the getting started guide here:
http://www.webassist.com/tutorials/Getting-started-with-HTML-Editor
Thank you Jason.
Is the File Manager aspect of HTML Editor different to the file fields option for the Data Bridge insert / update pages?
We want our user to be able to upload up to 3 product images one of which would be a thumbnail of the main image.
Much appreciated.
NJ
Yes, the file manager is different from the file upload.
Ok, let me re-phrase that question...which should we use to achieve what I have described?
Is the File Manager function to allow people to upload images within their formatted text?
Also, you might want to have a look at the text on the page you highlighted:
...there appear to be some odd HTML sections such as step 4 in the Applying to your Update page:
4.Change <input type=%u201Dtext%u201D> to <input type=%u201Dhidden%u201D>.
to upload multiple files, you will need to have multiple file fields, and multiple upload behaviors.
you could also use the file manager, but again, you would need multiple instances on the page.
I sugest you experiment with each to see the differences and determine which suits your needs best.
I will forward the comment about the tutorial to the documentation team
