Warning: require_once(../images/installed.jpg)
Thread begun 3/21/2014 12:34 pm by Surdej Web Solutions | Last modified 6/25/2015 1:29 pm by Ray Borduin | 10261 views | 27 replies |
I am getting this error after uploading my site to the live server:
Warning: require_once(../images/installed.jpg) [function.require-once]: failed to open stream: No such file or directory in /home/thom/public_html/WA_Globals/WA_Globals.php on line 60
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.jpg' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/thom/public_html/WA_Globals/WA_Globals.php on line 60
The image is there and the directory structure is correct. I am perplexed as to why it is not working. Any help is appreciated!
Thanks!
when you run the install, it will create the installed.txt file in the connections folder, make sure this is uploaded to the server so that it will not try to run the install again.
But if I run the install will it overwrite my current database?
no, but you wont need to run the install if you upload the connections/installed.txt file.
Okay. I uploaded it but now I get this again:
see PM
Thanks for your help!
you're welcome.
