Images not showing up via Image Resizer from instructions on eCommerce Webinar2
Thread began 3/23/2014 3:25 pm by cldsk | Last modified 5/13/2014 7:23 pm by Susanna | 2418 views | 8 replies |
cldsk
Hello, I have been following the instructions on eCommerce Webinar2 and the Image Resizer doesn't seem to be working - no images are displaying!
Also, my product description isn't displaying in cart?
I was also wondering where I could edit the color styles for the pages as the grey doesn't work well with my design.
Thank you so much!
see pm
cldsk
thx see pm
your images are being stored in the wrong place
accessing your site through FTP, the root shows the images/products folder is at the same level as the campargo-new folder.
The pages are looking for the images/products folder to be inside the campargo-new folder though.
cldsk
thanks please see pm
open the server behaviors panel, then double click the image resizer server behavior to edit it's settings.
to troubleshoot the other issue, I need some additional details.
I cant seam to find the add to cart page in order to add an item to the cart to see the errors on the cart page to troubleshoot. please provide steps to reproduce.
cldsk
the probelm was caused by the form action on the product details page:
action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>"?ProductID=<?php echo(intval($_GET['ProductID'])); ?>
needed to be changed to:
action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>?ProductID=<?php echo(intval($_GET['ProductID'])); ?>"
with ?ProductID=<?php echo(intval($_GET['ProductID'])); ?> outside of the quotes, it was not being included as part of the action so the recordset was empty.
in future, when using recordset info in the add to cart behavior, you should use the lookup Item ID option for the add to cart behavior.
Susanna
Are your image thumbnails not showing up? If the image resizer doesn’t work it will just show the post title instead of show image where the image was supposed to be. If you are using a theme with a javascript slider (Restaurant) you will not see this, but only the slider trying to load an image. First thing you should check is the image thumbnail URL.
