validation style
Thread begun 3/25/2014 9:46 am by Jamie | Last modified 4/07/2014 8:56 am by Jason Byrnes | 9385 views | 45 replies |
Jamie
validation style
Hi Jason
I have recently inserted a couple of forms to 2 different sites and in terms of the validation I dont *think* that I made any choices that were different to each other yet I have got validations as per the 2 images attached.
How would I go about using the validation style found on A and use it on B?
send a link to each form
Jamie
see PM
i dont see any validation errors on this form:
natalie/contact.php
the file:
webassist/jq_validation/Default.css
is missing
you can try replacing that file in the helliar domain with the one from the natalie domain
Jamie
thanks Jason.
Following on from that
In the attached screenshots, pre submit is how it should look but when you click on 'get in otuch' and one or more of the fields error on validation, it removes the styling from the input fields. URL in PM should you need it.
send a copy of the page please.
Jamie
here you go
hmmmm, dont see anything obvious in the code.
Jamie
See PM
the include/scripts.htm file included code that conflicted with the validation on the contact form. I commented the conflicting code.
