Coupon Codes and eCart6
Thread begun 3/26/2014 9:25 am by larry268887 | Last modified 3/28/2014 12:20 pm by Jason Byrnes | 4976 views | 12 replies |
larry268887
I've added a coupon code form to my cart page and everything works correctly as far as applying the correct discount when the correct discount code is entered. What I can't do is validate if a correct coupon code is entered. How can I validate when someone enters a coupon code if it is a valid coupon code and if it isn't valid display a message not a valid coupon code?
you would need to hand code this:
if(isset($_POST['CouponCode']) {
if($_POST['CouponCode'] != "ValidCode") {
$_SESSION['badCoupon'] = "yes";
} else {
$_SESSION['badCoupon'] = "no";
then to show the error:
<?php if(isset($_SESSION['badCoupon']) && $_SESSION['badCoupon'] == "yes")) echo "you entered an incorrect coupon code"; ?>
larry268887
Lets say that I have 3 valid coupon codes: 1.airflight 2.facebook 3.pinterest How should the top portion of the code be written?
if(($_POST['CouponCode'] != "airflight") || ($_POST['CouponCode'] != "facebook") || ($_POST['CouponCode'] != "pinterest")) {
larry268887
I can't seem to get it to work can you take a look at the code and tell me what I'm doing wrong?
you have the code inside a validatonb show if:
if (ValidatedField('cart','cart')) {
if ((strpos((",".ValidatedField("cart","cart").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
if(isset($_POST['Coupon_Code'])) {
if(($_POST['Coupon_Code'] != "airflight") || ($_POST['Coupon_Code'] != "facebook") || ($_POST['Coupon_Code'] != "pinterest")) {
} else {
<?php if(isset($_SESSION['badCoupon']) && ($_SESSION['badCoupon'] == "yes")) echo "you entered an incorrect coupon code"; ?>
<span class="serverInvalidState" id="Coupon_Code_ServerError">Please enter valid coupon code</span>
<?php //WAFV_Conditional cart.php cart(1:)
it needs to be outside of the validation show if.
larry268887
Moved it outside and I'm getting closer but whether you out in a valid code or invalid it says the coupon code is invalid. Here is the code:
$_SESSION['badCoupon'] = "yes"; }
else {
Can't figure out why all coupon codes are invalid.
larry268887
Here is the requested info
larry268887
When you compare to only one coupon code everything works fine.
if($_POST['Coupon_Code'] != "airflight") {
} else {
This code works fine. Its the code for three coupon codes that isn't working
else {
