Why am I getting an "Error in applyServerBehaviour" message and the email section is failing to create.
Thread begun 3/26/2014 10:42 am by Andrew Read | Last modified 3/26/2014 10:49 am by Andrew Read | 936 views | 1 replies |
Andrew Read
Hello,
I am creating a slightly customized basic contact form using the Forms > Insert New Form behaviour and none of the email customizations work, and the email behaviour is not created. I receive the error message that is attached.
If I click on the button at the top of the email form page (which IIRC is the email customization form) it simply opens and closes itself.
When I submit the form to create, I get the error attached. The form is created but there are no email behaviours on the page.If I try to 'Create Email Message' from the Webassist menu the window simply opens and then immediately closes itself.
Please help!
Andrew Read
Nevermind.. I am installing the eCart update, which I suspect will fix the issue.
