If conditions are met when user updates record, insert a new record in second table
Thread begun 4/07/2014 11:33 am by Paul | Last modified 4/07/2014 12:11 pm by Jason Byrnes | 872 views | 1 replies |
PaulBeta Tester
Using latest Data Bridge
I have setup a user account which a logged in user can update at will.
If the user checks a field in table 1, on update i want to duplicate the address fields into table 2.
This would be a unique record in table 2, to avoid adding new records of the same data everytime a user updates their account in table 1
What would be a simple workable approach to trigger the insert event if it was a unique record?
Thanks, Paul.
it would require hand coding. you would need to have a recordset to lookup the address then add an if statement around the insert so it would only happen if the recordset is empty.
we could help set this up in a premiere support appointment.:
http://www.webassist.com/premier_request.php
