Show Multiple Dynamic Addresses Pro Google Maps
Thread begun 8/21/2009 8:05 am by omar386399 | Last modified 8/27/2009 9:30 am by Jason Byrnes | 7142 views | 5 replies |
omar386399
The Show Multiple Dynamic Addresses in Pro Google Maps will not work.
If I uncheck the Show Multiple the maps loads correctly, However I have Multiple locations In my recordset that i need show on the map and the the page simply will not load when I choose the show multple option. I don't get any error messages , just a blank webpage, If I click the view source on the page I can see all addresses in the code.
Please Help
here is an example
test.asp
If you view source of the page, you will see the following error:
var address_0_48 = {
street: ' <font face="Arial" size=2>
<p>Microsoft VBScript runtime </font> <font face="Arial" size=2>error '800a005e'</font>
<p>
<font face="Arial" size=2>Invalid use of Null: 'CStr'</font>
<p>
<font face="Arial" size=2>/Corp/SM/google_javascript/wagmp_map_3.asp</font><font face="Arial" size=2>, line 147</font>
This means that one of the records in your database has a NULL value in the street column.
Make sure that all of the addresses in your database are complete and have a value for the street column
omar386399
Forward only recordset cursor position.
Thank you , I am Acutually having another issue with the recordset.
I am now getting the following error msg:
<p>Microsoft OLE DB Provider for ODBC Drivers</font> <font face="Arial" size=2>error '80040e18'</font>
<p>
<font face="Arial" size=2>Rowset position cannot be restarted.</font>
<p>
<font face="Arial" size=2>/Corp/SM/google_javascript/wagmp_map_2.asp</font><font face="Arial" size=2>, line 264</font>
I am using dreamweaver CS3 which I don't think has any other cursor option other then Forward Only ?
example:
salesmapperresultsX.asp?PostalCode=L8R
Any advice?
you could force it to use a static cursor by adding code similar to this in the recordset:
recordsetName.Cursortype = 3 'adOpenStatic
omar386399
Using
"recordsetName.Cursortype = 3 'adOpenStatic "
Does not work in a CS3 created record set
I get a Object doesn't support this property or method error
OK, try using this instead:
RecordsetName_cmd.ActiveConnection.cursorLocation = 3
