My page does not redirect to the GOTO page
Thread begun 4/13/2014 10:43 am by dsnoyes418343 | Last modified 4/15/2014 8:22 am by Jason Byrnes | 2017 views | 3 replies |
dsnoyes418343
Hello,
I've been using Universal Email with great success for a few years now - but recently I set up a new form for a boarding kennel online reservation form and the visitor is not being redirected to the thankyou.html page as set up in the email message for the Go To Page (I am using Button: Submit pressed).
Here is the page with my form: http://www.moonlitekennels.com/ReservationForm.php
When the form is completed, the page just seems to reload. I need the visitor to be redirected to http://www.moonlitekennels.com/thankyou.html so they know the message went through.
The form data is emailed to me perfectly fine - it's just the redirect that isn't working. As I said, I've done dozens of these with success, but for some reason, this one just isn't working like all the rest!
Any assistance is greatly appreciated!
Sue
there is probably an error occuring that is causing the reddirect to fail.
add the following code at line 1 to turn error reporting on:
error_reporting(E_ALL);
test the page again and report any errors that are displayed, also, attach a copy of the ReservationForm.php file to your reply.
dsnoyes418343
Error Reporting and File Attached
I turned error reporting on and see this at the top of the page right away:
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/webassist/form_validations/wavt_validatedform_php.php on line 3
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/webassist/form_validations/wavt_validatedform_php.php on line 3
I got this after submitting the form:
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/ReservationForm.php on line 77
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/ReservationForm.php on line 77
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/webassist/email/mail_php.php on line 285
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/webassist/email/mail_php.php on line 285
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/ReservationForm.php on line 107
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/ReservationForm.php on line 107
Warning: Cannot modify header information - headers already sent by (output started at /home/moonlite/public_html/ReservationForm.php:1) in /home/moonlite/public_html/ReservationForm.php on line 109
Thanks in advance for your help!
Sue
This error is happening because the BOM signature is enabled for the page.
Go to Modify -> Page Properties
in the Title / Encoding section, uncheck the Include Unicode Signature (BOM) option.
NOTE: when you added the error reporting code block, you also included a blank line between php blocks. you will need to also delete the blank line at line 5.
see this post for more details on the headers already sent error:
http://www.webassist.com/forums/posts.php?id=19285
