Making a survey with Form Builder
Thread begun 8/21/2009 9:44 am by khuntsinger387372 | Last modified 9/13/2009 7:50 am by sales326752 | 9546 views | 20 replies |
khuntsinger387372
Can you use this program to make a survey form? I purchased it thinking I could and I fear I may be incorrect............ Any help is appreciated.
Jimmy Wu
What kind of form elements do you want on this survey form?
Form Builder allows you to customize the forms to suit your needs, so you should be able to create a survey form.
khuntsinger387372
Survey
I just have 8 different questions with either a Check box or drop down menu. At the bottom is an address field city, st, zip etc. Very simple.
Jimmy Wu
There shouldn't be any problem creating a form for your survey using the tool then.
khuntsinger387372
Form Builder
Then it sounds like I need to custom make those fields prior to actually building the form then is that correct?
Jimmy Wu
There are check boxes and drop down menus already, but you would have to modify them to suit your needs. Add in the options you need, the checkbox label, etc.
caryn191788
CSS Form Builder - How to add email function
HI, I have recently purchased the CSS Form Builder - I find that is builds forms nicely however there are no instructions of how to add the email function so a client could receive an email. I also have the Contact Form builder. I have trouble with contact forms working smoothly hence why I purchased the builder. Could you please forward instructions on how to complete the form to work.
I most likely have the software applications from Web Assist just not too sure how to put them together.
Caryn
Use Universal Email and apply the server behavior in DW on the Action page of the form. From there designing the email and contents should be easy.
khuntsinger387372
Checkbox group
Why is it I can select as an example both Yes and No in check box when I should only be allowed to select one?
Checkboxes will allow for multiple selections within a group. If you would like to limit the user to make a single selection you should be using the radio group instead.
