Start Date or Issue Number is required - Payment Unsuccessful
Thread begun 4/14/2014 3:35 am by Nathon Jones Web Design | Last modified 4/17/2014 8:24 am by Jason Byrnes | 10616 views | 24 replies |
We're receiving an error when using the test Maestro card details provided by PayPal Sandbox.
"Failure9620887c5e3f2Invalid DataA Start Date or Issue Number is required.10567Error60.01043306457.00" }"
This obviously relates to the fact that eCart doesn't ask for a start date or issue number. How do I add this to my confirm.php so that the correct values are sent to PayPal?
Thank you.
NJ
Edit the credit card form on the confirm page to add filds for:
startMonth
startYear
issueNumber
Then open the server behaviors panel, double click on the eCart Local Checkout server behavior to edit it.
on the 4th page, bind the startMont, startYear and Issue number variables to the form fields added to the credit card form.
Can I copy the drop-down menu fields from the Expiry Date section, except obviously I'd have to rename these to Card_Start_Month and Card_Start-Year:
<div class="lineGroup">
<div class="fullColumnGroup"><label for="Card_Exp_Month" class="sublabel" >Expiration date :<span class="requiredIndicator">&nbsp;*</span></label>
<select class="formMenufield_Medium" name="Card_Exp_Month" id="Card_Exp_Month" rel="<?php echo((isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")); ?>" tabindex="103" title="Please select a valid expiration date" required>
<option value="1" <?php if (!(strcmp("1", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>January</option>
<option value="2" <?php if (!(strcmp("2", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>February</option>
<option value="3" <?php if (!(strcmp("3", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>March</option>
<option value="4" <?php if (!(strcmp("4", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>April</option>
<option value="5" <?php if (!(strcmp("5", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>May</option>
<option value="6" <?php if (!(strcmp("6", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>June</option>
<option value="7" <?php if (!(strcmp("7", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>July</option>
<option value="8" <?php if (!(strcmp("8", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>August</option>
<option value="9" <?php if (!(strcmp("9", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>September</option>
<option value="10" <?php if (!(strcmp("10", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>October</option>
<option value="11" <?php if (!(strcmp("11", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>November</option>
<option value="12" <?php if (!(strcmp("12", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Month"):"")))) {echo "selected=\"selected\"";} ?>>December</option>
</select>
if (ValidatedField('confirm','confirm')) {
if ((strpos((",".ValidatedField("confirm","confirm").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="Card_Exp_Month_ServerError">Please select a valid expiration date</span><?php //WAFV_Conditional confirm.php confirm(3:)
<select class="formMenufield_Small" name="Card_Exp_Year" id="Card_Exp_Year" rel="<?php echo((isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")); ?>" tabindex="104" title="Please select a valid expiration date" required>
<option value="" <?php if (!(strcmp("", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>Year</option>
<option value="2014" <?php if (!(strcmp("2014", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2014</option>
<option value="2015" <?php if (!(strcmp("2015", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2015</option>
<option value="2016" <?php if (!(strcmp("2016", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2016</option>
<option value="2017" <?php if (!(strcmp("2017", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2017</option>
<option value="2018" <?php if (!(strcmp("2018", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2018</option>
<option value="2019" <?php if (!(strcmp("2019", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2019</option>
<option value="2020" <?php if (!(strcmp("2020", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2020</option>
<option value="2021" <?php if (!(strcmp("2021", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2021</option>
<option value="2022" <?php if (!(strcmp("2022", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2022</option>
<option value="2023" <?php if (!(strcmp("2023", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2023</option>
<option value="2024" <?php if (!(strcmp("2024", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2024</option>
<option value="2025" <?php if (!(strcmp("2025", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2025</option>
<option value="2026" <?php if (!(strcmp("2026", (isset($_GET["invalid"])?ValidatedField("confirm","Card_Exp_Year"):"")))) {echo "selected=\"selected\"";} ?>>2026</option>
</select>
if ((strpos((",".ValidatedField("confirm","confirm").","), "," . "4" . ",") !== false || "4" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="Card_Exp_Year_ServerError">Please select a valid expiration date</span><?php //WAFV_Conditional confirm.php confirm(4:)
</div>
</div>
I assume I'll have to edit the Server Validation server behaviour to add these two new fields?
And I only need them to be required for Maestro/Switch cards. Is there a way to make the validation dependent on the selection made in the Card_Type drop-down? Or to hide them and replace them with hidden form values should Maestro/Switch be selected?
Would appreciate your advice. Thank you.
NJ
Changed the confirm.php page to have the following (I attach it also). Basically stripped out all of the validation:
<label for="Card_Start_Month" class="sublabel" >Valid From (Maestro/Switch):<span class="requiredIndicator">&nbsp;*</span></label>
<select class="formMenufield_Medium" name="Card_Start_Month" id="Card_Start_Month" tabindex="105" title="Please select a valid start date">
<option value="1">January</option>
<option value="2">February</option>
<option value="3">March</option>
<option value="4">April</option>
<option value="5">May</option>
<option value="6">June</option>
<option value="7">July</option>
<option value="8">August</option>
<option value="9">September</option>
<option value="10">October</option>
<option value="11">November</option>
<option value="12">December</option>
</select>
<select class="formMenufield_Small" name="Card_Start_Year" id="Card_Start_Year" tabindex="106" title="Please select a valid start date">
<option value="">Year</option>
<option value="2005">2005</option>
<option value="2006">2006</option>
<option value="2007">2007</option>
<option value="2008">2008</option>
<option value="2009">2009</option>
<option value="2010">2010</option>
<option value="2011">2011</option>
<option value="2012">2012</option>
<option value="2013">2013</option>
<option value="2014">2014</option>
</select>
</div>
</div>
<label for="Issue_No" class="sublabel" >Issue Number (if applicable):<span class="requiredIndicator">&nbsp;*</span></label>
<input id="Issue_No" name="Issue_No" type="text" class="formTextfield_Large" tabindex="107" title="If your card has one, please enter your issue number">
</div>
</div>
How do I make these two sections only display if "Maestro" is selected from the Card_Type drop down?
And how do I trigger any validation on those fields to only run if "Maestro" is selected?
When I submit the form now, I initially received an error about an invalid country code and when I checked, I had manually added "England, Scotland, Northern Ireland, Wales" as countries in their own right, with their titles as the country code. I changed them all to "GB", although I'd ideally like to allow the option to enter either England, Scotland, Northern Ireland and Wales, and it didn't produce that error any more however we now receive the following error:
array(8) { ["LEDCart_Items"]=> string(251) "585|WAECART|LWP0252|WAECART|40 Watt RGB LED Flood Light (includes remote)|WAECART|LWP0252.jpg|WAECART|0|WAECART|1|WAECART|105|WAECART||WAECART||WAECART|0|WAECART||WAECART|0|WAECART|139754767462|WAECART|0|WAECART|105|WAECART|1 LWP0252 (585)|WAECART|105" ["WAEC_ContinueRedirect"]=> string(30) "/LED-Lights-Bulbs.php?lbid=585" ["WASF_CheckoutWizard_Sharp_Default"]=> array(31) { ["plugin_from"]=> string(43) "https://www.ledwarehouseuk.com/checkout.php" ["plugin_file"]=> string(16) "confirm_cart.php" ["payment-type"]=> string(10) "creditcard" ["First_Name"]=> string(19) "Nathon Test 1504 06" ["Last_Name"]=> string(5) "Jones" ["Email_Address"]=> string(24) "admin@ledwarehouseuk.com" ["Phone_Number"]=> string(12) "01671 404924" ["Company_Name"]=> string(0) "" ["Address_1"]=> string(14) "1 Main Terrace" ["Address_2"]=> string(0) "" ["City"]=> string(13) "Wolverhampton" ["Country"]=> string(2) "GB" ["State_Hidden"]=> string(0) "" ["State"]=> string(13) "West Midlands" ["Postal_Code"]=> string(7) "W12 4LQ" ["Shipping_SameAs_Billing"]=> string(1) "1" ["First_Name_2"]=> string(19) "Nathon Test 1504 06" ["Last_Name_2"]=> string(5) "Jones" ["Email_Address_2"]=> string(24) "admin@ledwarehouseuk.com" ["Phone_Number_2"]=> string(12) "01671 404924" ["Company_Name_2"]=> string(0) "" ["Address_1_2"]=> string(14) "1 Main Terrace" ["Address_2_2"]=> string(0) "" ["Country_2"]=> string(2) "GB" ["State_2_Hidden"]=> string(0) "" ["State_2"]=> string(13) "West Midlands" ["City_2"]=> string(13) "Wolverhampton" ["Postal_Code_2"]=> string(7) "W12 4LQ" ["CheckoutWizard_submit"]=> string(0) "" ["_ga"]=> string(27) "GA1.2.1265700428.1396992615" ["PHPSESSID"]=> string(32) "61570fa65f3b938e8750ce1cc1546534" } ["WAVT_confirmcart_Errors"]=> string(0) "" ["WASF_WA_Payments"]=> array(12) { ["Card_Type"]=> string(7) "Maestro" ["Card_Number"]=> string(16) "6759106074534277" ["Card_Exp_Month"]=> string(1) "3" ["Card_Exp_Year"]=> string(4) "2019" ["Card_Start_Month"]=> string(1) "8" ["Card_Start_Year"]=> string(4) "2012" ["Issue_No"]=> string(1) "2" ["Card_CVV"]=> string(3) "546" ["Payment_submit"]=> string(0) "" ["_ga"]=> string(27) "GA1.2.1265700428.1396992615" ["PHPSESSID"]=> string(32) "61570fa65f3b938e8750ce1cc1546534" ["CardLast4"]=> string(4) "4277" } ["WAVT_confirm_Errors"]=> string(0) "" ["PP_DirectPayment_postedValues"]=> string(2362) "testled_api1.nathonjones.com1397034159AWqYshSunm8L6wf2fZRSi926up.GAdtvGHEXzLdfJYFQdRK2ug21CHOD60.0Sale108.003105WebAssist.eCartPHP.Pro.DPLWP02521051585Nathon Test 1504 061 Main TerraceWolverhamptonWest MidlandsW12 4LQGB01671 404924Maestro675910607453427732019verifiedNathon Test 1504 06Jonesadmin@ledwarehouseuk.comGB
1 Main TerraceWolverhamptonWest MidlandsGBGBW12 4LQ01671 404924
54682012281.156.217.18661570fa65f3b938e8750ce1cc1546534" ["PP_DirectPayment"]=> string(2254) "2014-04-15T07:44:38ZFailurebcae2a3c1646Transaction is not compliant due to missing or invalid 3D-secure authentication valuesTransaction is not compliant due to missing or invalid 3D-secure authentication values12000Error60.010433064108.00" }
Would appreciate your assistance. Thank you.
NJ
to show those fields only when Maestro is selected you would need to write a javascript function to trigger on the onChange event of the card type select list.
for the validation to happen when maestro is the selected option would also require hand coding. you would need an if statement around the validation for those fields.
the error I believe is caused by the start month format, it needs to MM
so
01
012
etc
We could help you with the hand coding in a premiere support appointment:
http://www.webassist.com/premier_request.php
Is the error not relating to 3D Secure Authentication?
We've tried a test with a Visa card and it works just fine (because Visa's don't require 3D Secure Authentication) which suggests that there is no problem with our start month format.
When you say you could help with the hand coding, does that mean you pretty much do it for us bar the actual dropping it into the page/s required?
I have no JavaScript skills (any skills period!)...as you know. ;)
Also, I've noticed that in a test order the "TruePrice" value, required because our unit price has incremental values added to it, isn't being saved to the OrderDetails table, just the regular unit price. Do I need to change a binding there? Which page is that?
to use 3d secure, you need to sign up with them to have an account.
then on the confirm page, edit the local checkout server behavior, on the 4th page, add these 4 variables by clicking the plus button:
AUTHSTATUS3DS
MPIVENDOR3DS
CAVV
ECI3DS
XID
and use the values provided by the 3d secure service
Yes, in the Premier support appointment we will do a screen sharing session and implement the code teaching you what we are doing along the way.
for the order details, edit the store order details behavior on the Confirm and on the pp_confirm page to bind the price to the true price.
That's 5 variables, not 4. Should it be 4 or 5?
When would suit you for the Premier support assistance session?
Thank you
NJ
yes, it should be 5.
sign up for a premiere appointment here:
you will then be contacted to set the appointment time.
I've signed up with Cardinal Commerce / Cardinal Sentinel as per instructions from PayPal with regard to 3D Secure Authentication. What should each of these fields map to?
AUTHSTATUS3DS
MPIVENDOR3DS
CAVV
ECI3DS
XID
The only thing, within the Cardinal Commerce control panel, that resembles any of the above is "CAVV/XID Format" which is listed as "Base64 Encoded".
I've requested Centinel Integration software and documentation for:
Verified by Visa
MasterCard SecureCode
Maestro
...do I just need to wait for them to send me details for the 5 variables you've listed? They've sent us a PDF for "Cashie - WebAssist Setup Guide" but it doesn't relate to what I'm seeing in eCart (attached).
Regarding the Premier Support we've requested, is it ok to run through as much stuff as possible during that session so that we can iron out absolutely everything and, finally, get this project moving?
Thank you.
NJ
