Form throwing error on submit
Thread began 4/17/2014 3:27 pm by phill401410 | Last modified 4/22/2014 9:19 am by Jason Byrnes | 2147 views | 14 replies |
phill401410
The attached form throws error: Fatal error: require() [function.require]: Failed opening required 'Center.php' (include_path='.:/usr/share/php:/usr/services/vux/lib/php') in /data/20/1/125/115/1940604/user/2116827/htdocs/thilldesign/webassist/email/mailformatting_php.php on line 15
when I submit the form
Can you point me in the right direction to resolve? Thank you.
WA DingbatInfoRequest 17APR14.ZIP
make sure to upload the entire webassist/email folder including the webassist/email/templates/Center.php file.
phill401410
yes, the entire folder with Center.php is on the remote server. I found the file Center.php in waue_InfoRequest_1.php and changed the path from: $MailBody = $MailBody . (GetFromPage("../templates/Center.php"));
to
$MailBody = $MailBody . (GetFromPage("http://thilldesign.com/dingbatstore/webassist/email/templates/Center.php")); on line 40
did not work
phill401410
thanks, Jason, info in PM
So, Dreamweaver places files at the root of your site definition.
in the ftp site, the path for the email file is:
/htdocs/thilldesign/dingbatstore/InfoRequest.php
in the dingbatstore/InfoRequest.php file, the path it uses to look for thewebassist/email/waue_InfoRequest_1.php file is
include("../webassist/email/waue_InfoRequest_1.php");
meaning it is looking for the webassist folder a directory down form the dingbatstore folder at:
/htdocs/thilldesign/webassist/email/waue_InfoRequest_1.php
in the templates folder at that location there is no Center.php file
there is one at the
/htdocs/thilldesign/dingbatstore/webassist/email/
location though.
i moved the template file that was at:
/htdocs/thilldesign/dingbatstore/webassist/email/templates/Center.php
to the location it was being looked for:
/htdocs/thilldesign/webassist/email/templates/Center.php
phill401410
Thank you, Jason, works fine now and I even understand the logic behind your explanation. Progress! Eventually will move this client back to their own server at 1and1 where we have to upgrade to a hosting package that will allow php files to connect to database.
you're welcome.
phill401410
Jason
So, I upgraded my basic 1and1 package and can now connect php files to the server. Unfortunately this file, http://dingbatstore.com/InfoRequest.php, is not connecting.
However, this file http://dingbatstore.com/InfoRequest.php5, does connect. Go figure. It throws a preformatted 1and1 error:
Error 404: NOT FOUND!
This domain name has just been registered.
I've included files in attachment and link to the site where you can see the problem occur and ftp login details in a PM so you can access the site files directly to troubleshoot.
WA DingbatInfoRequest 21APR14.ZIP
looks to me like you have a server setting that is rewriting the page extension from:
.php
.php5
you should contact 1&1 support about this problem, it looks to be a server setting issue.
