Split search results into tabs with record count on each
I have created a search results page and it is working to a degree. However i am trying to display the results in 4 tabs with a record count for each column, The results all relate to each other from the one search form but the Services and Promotions data is not correct.I created 4 recordsets on the results page (not sure if this was the correct way achieve this), i have tried using the session "WADbSearch1_search_results" to filter the results but it is not working correctly..
I have attached the results page.
